i cant make a 90 deg angle..
Darrin Hill
so the reason i use a lathe is im good at makign square things round....
im building a dresser and my carcass is slightly not square..... and its glued and screwed... so do i use some kinda plane to fix it or?
d
Re: i cant make a 90 deg angle..
Jack Guzman from Maine
Out of square in which direction? Looking down at the carcass ,facing it from the front ,or facing it from one of the ends.---Jack
Robin Corell in Atascadero,CA
It doesn't need to be square, it only needs to look square.
Dick Coers
Yeah, we need a lot more details. Just making the case square by hand planning isn't going to make fitting the drawers any easier. What direction is out of square?
Jerry Gibbs
If you have to make several drawers, you may want to remake the carcass. I don't know how valuable the wood is, but maybe you can salvage the top and sides. Making drawers fit is harder than fitting an overlay door to a carcass that is out of square. If you are having trouble making square joints for the case, you will for the drawers also.
From my vast experience at mistakes, here are two tips. First make sure the cuts are square both across the board and in the thickness dimension. Check it often if your technique is the problem and not the saw set up. The other is to not try to glue up to much at a time. Using large square glue-up guides is a help. You can make these yourself with a square piece of plywood with holes for clamps.
Totally agree
Chalk it up to gaining more knowledge. We have all been there. And once you have done it, you'll remember to check for square before the glue sets. (or in my case, after a couple of such blunders.
Robin is right....if it's not really obvious, then work with it as is. Doors and drawers might need to be tweeked to compensate. But as a whole, it should not be that obvious.
Moses Yoder
Moses Yoder
I have built thousands of kitchen cabinets and am now building range hoods. I build about 2 range hoods per day. Nothing I have ever built has been square. Close enough, but not square.
