Cat Exercise Wheel
Cat Exercise Wheel
Cat Exercise Wheel
Don Stephan
Recently we adopted two kittens, one now 13 weeks and the other now 10 months. The latter is so high energy he is wearing out his new sister, and commercial cat exercise wheels are quite expensive. So I'm hoping to build an exercise wheel about 48-52" in diameter using 1/2" or 3/4" baltic birch and several layers of 1/8" poplar bending plywoods. I'm not sure how to attach the built up rim to the baltic birch back, and how to add a bearing and mount on a stand. One on line video used a metal hub lawn mower wheel, bolted to the wheel's back, but there might be a better way. Can anyone offer any suggestions for this offbeat woodworking project?
Re: Cat Exercise Wheel
Ken Garlock Colin County Texas
Hi Don. Before you get into a big project, try this simple solution. Go to your local Pets-mart or Pet-Co, and buy a cat toy on a stick. By that I mean, a toy with an elastic string that has a feather toy on the end of the string. Your job or someone in your family is to play with the hyper kitty several times a day for periods of ten minutes. Also check out the Saturday evening Animal planet program Cat From Hell. It is entertaining and educational.
Cats are fun little pets, LOML and and I have had at least one cat at all times during our 40 years of wedded bliss. Those 40 years were marked last month with dinner at Ruth's Cris.
Good luck with your kitty,
and happy saw dust,
Ken
Treadmill
Joe in a Cleveland suburb
We occasionally run our dogs (Golden Retrievers) on a treadmill to burn up extra energy and for the exercise.
Might work with cats too. IDK.
If you happen to have a treadmill, might be worth a try.
We have a similar situation except ours are now 1 year old and 2 years old.
We went to Petsmart and got a laser toy. This allows the cats to tear around chasing the little red dot. All we have to do is wave our hand.
The Pet Toy Axiom
Tom Dunlap
The more you pay for a pet toy the more likely it won't be noticed.
One pot holder became a toy for us. Tom eventually gave up trying to keep it hung up and it's on the floor.
Plastic bottle caps!
Twist ties
Flying insects...we kills dem all!
~~~Scourge, Bandit and Patch
Pete in Holland, MI
A large paper drum, or plastic drum. Cut a circle from the diameter. Slip it over a disk of plywood. Bam ! A hamster style wheel.
Keeping the cat on the wheel will be the challenge.
As mentioned earlier, a laser is good fun. We used to tie a small fuzzy mouse toy to a fishing pole line, thread it all over the house around various table leg, then real it in as fast as we could. Kept the cat running, and us laughing, for several days until the cat figured us out.
You have a young cat. They will eventually get complacent, and once he learns how to control you, will lay around waiting to be cared for.
fur
Charles Yawn
Recently, our cats, Stretch and Foxy, were batting around a tuft of their own fur.
Charles
Re: fur
Don Stephan
We play at least 10 minutes each morning and evening, and Tuck doesn't get enough. He's wearing Janis down with his physical play, needs a way to burn off more energy. We've taken away his 5 Hr energy account and his Starbucks charge card, and he's still too active. Don't have a treadmill. Will try laser pointer, but still hoping to develop plans for the exercise wheel.
Dave in Bryn Mawr
Don't want to be a wet blanket, but do you really think the active cat will use it? They have their own agendas!
I had to look it up
Gary Smyth
I have to say for $489 you could hire some school kid to play with the animal for a whole summer. The thing is big -- 43" in diameter (46" total) and 10" wide (excluding base) and weighs 46 lbs.. The only thing that comes to mind that might work is the fan shroud for a floor mounted industrial fan. You might check with someone who makes duct work, but that metal is normally too thin for this application. If not dampened the noise would not be tolerated by my animals. The duct company might be able to do it though. If other than metal you can perhaps find a used base drum but it will likely be smaller. If it is made of lumber yard wood the weight to hold a 10 lb moving cat will be even more than metal. I think that at the price the monster exerciser is risky as to use and then where will it go when the cat gets bored- reused as a fire pit?? My alternative suggestion would be to try an endless loop rope stretched between stanchions with pulleys. Use a motor to power the pulley to drive the rope back and forth around the pulley and make a feather drag or catnip bag for the cat to chase. The added benefit is you can break it down and can get rid of it if it isn't appreciated.
Keith Newton
An old attic fan, would make a good foundation to start with. Take the blades off, and you make the rest.
The track would make a fun vacuum bagging project, if you wanted to do it all in wood. If you are adventurous, I can talk you through it.
I would add a little arm, which comes around the side, which would hold a laser pointed toward the opposite side, with a little tickler of some sort, maybe magnets inbeded in the rim, to make the laser jump around, just ahead of the cat's reach.
Tom Dunlap
You'd have the laser on a motion detector switch I know too. It would be the Pavlovian reward for Pooder Kat to chase.
A.J. Hamler
Take the blades off first?
A.J. Hamler
Depends on how much you like the cat, I suspect.
A.J.
Larry in nw ohio
Tom That wheel sounds interesting, could you make up a sketch of it and post it. Thank You Larry
Bruce Mack
The little one will catch up in time. An exercise wheel is a one cat conveyance and may not be used when they are co-conspirators chasing each other around the house. Consider making a lattice gymnasium with box-like hidey holes and canvas rest areas. 2x4s or 3x3s should do, and can be painted. You'll be da man:)
Yeah, but what if they catch it?
