OT sorta-Air Compressor Cycle
Alan Young
Alan Young
On the Day job we have a 150 liter JunAir Model 4000M-150B Compressor.I recently drained the entire system and replaced the intake filters and a check valve. I turned it on to re-charged the system. I am only charging the tank at this point-not the lines.The cycle should shut off at @125 psi. It has taken 45 minutes to get to 75 psi. This seems to be an excessive length of time for charging the tank. The tech manual has no information saying what to expect and all tech support is ridiculously cumbersome to access so I thought I'd at least ask here what is an acceptable time to pressurize the tank.
-Alan
Re: OT sorta-Air Compressor Cycle
Keith Newton
I would bet that the check valve is leaking. It may have a hole which is suppose to drain the pressure over the head when it closes the back flow, but is open full-time.
Pull out the spray bottle with soap.
Not sure what it should actually be, but way less than forty five minutes.
I suggest you check the bleeder on the pressure shut off switch and see if it stuck in the open position. I'm calling it the bleeder, but its the little mechanical device that lets the pressure off the lines to let the compressor start without working against the head of the system.
Obviously you know to check for other leaks.
That's The
"Unloader valve".
Re: Air Compressor
If you've doped and checked all of your connections, it sounds like you have a valve problem; most likely the intake valve is not seating properly which allows air to back flow out the intake and filter.
To determine this you'll need to depressurize the unit. Unplug it. Remove the cylinder head, and inspect the two valves and the valve seats when you cycle the cam by hand.
Possible problems:
1. Piece of debris preventing the intake valve from sealing.
2. Bad lifter.
3. Bad valve spring.
4. Cracked cylinder wall.
5. Worn or damaged piston ring(s).
6. Leaking unloader or output line.
If when you shut it off,
Keith Newton
If the tank holds the 75 psi, the leak is above the check valve, so do your soap spray above that.
If it leaks after shutting off, it may be the drain plug, or under the check valve.
If the tank pressure holds after the power is off, the soap won't show anything above the check valve, unless the pump is running, so try to find ways to eliminate all the possibilities.
Since you changed the filters, there is a slight chance of a connection there, but I'd say small, unless there is something, weird.
As large as this leak sounds, you should be able to feel it with your hands, or hear it with your ears, unless the pump is really loud, and you are as old as most of us who frequent this forum, and ,,,,,,,,,,,,,,,,,,,,,,,, uhhhh, I forgot what I was going to say. ha
walta
The formula from this web site with numbers for your unit 0 to 125 PSI equals 9.7 minutes
http://www.about-air-compressors.com/fill-an-air-tank.html
3.9 gallon tank
7.77 cfm
Likely the valves in the pump have seen better days.
Once it is at pressure shut it down if you can’t hear a leak you have a pump problem.
Walta
Alan Young
Youz gyz are great-I'll have at it tomorrow
Something big is open
Dick Coers
As mentioned, something BIG is open for it to work like that. Almost like the end off the hose kind of size. It's not going to be a pin hole thats for sure! Did you put the valve on correctly? It's not able to go on backwards is it? I'm not sure I ever knew about a check valve on a big compressor. Sure never checked on mine if there is one.
40 gallons should fill in less than 10 minutes
RobCarr
A leak that large you should be able to hear it.
Re: 40 gallons should fill in less than 10 minutes
Larry in nw ohio
Alan I`ll try to chime in here for what that will do. If the compressor worked well before the take down, and didn`t afterwards, then something may have gotten on a little wrong. But the first thing to do is just listen when it`s off. If you do not hear anything, then I believe something went on wrong, and it`s not getting air in the tank when it`s pumping, which would be something after the valves. But as others said if it doesn`t pump then somethingthing inside may be wrong. I hope some one helped you out and you getit fixed. What kind of place do you work at and how big is it? Larry
Larry in nw ohio
Alan I reread your post and you did something with the check valve. That may be the problem, check and double check that, make sure that is working right and on correctly. Larry
Alan Young
Update
Alan Young
Thanks for all the comments people. AT this point the check valve has been replaced (at the earlier suggestion of the Jun-Air tech support). I don't think anything was wrong with the original as the new one I installed shows no signs of leaking(Or any other leaks for that matter. It still takes too long to build pressure so the next step will be to check piston rings (according to Jun-Manual) and valves/seating based on comments here at WC. Thanks again for your help the haystack is getting smaller.
-Alan
Re: Update
Pete in Holland, MI
Is this an oil sump, or oil-less compressor ?
Oil-less compressors have a small duty cycle. Excessively long run times will over heat the piston seals. Twas the reason I paid a few more dollars and bought an oil sump compressor.
Pete
del schisler
do the intake filter's have a arrow as to which way they go?? may be wrong ? did the compreasor work before the filter change ?? just thanking may be like a check valve , only goes in 1 way ?
Dale Lenz
Dale Lenz
Allan, how about putting the old check value back in just for the heck of it?
