May have stepped into it
Gary Smyth
The pictures are 200% actual size. I was asked if I could make the currently existing lower picture look (more) like like an eagle as drawn on the upper one. I was told that the item was aluminum but it turns out to be 1/8" stainless. Originally I thought that a couple of quick cuts on the band saw and then some file work would do the job but aluminum, which this is not, is much easier to work that the stainless it is. I was hoping to band saw major cuts still, if possible, but I need to get a blade. I have a 14" Delta bad saw and a drill press. What cuts stainless? Teeth? Bimetal? I also have a 1" x 42" upright belt sander, a Foredom tool (I'd have to buy a proper head) for the close(r) work if that helps. The quarters are pretty tight. Once started there is little room to undo a bad choice. This shouldn't be too difficult if the right tools are available and care taken, but that stainless is hard and the tool wants to wander.
Re: May have stepped into it
Larry in nw ohio
Gary Do you happen to know anyone with a Laser. That should make short work of it. Cost I don`t know. Maybe someone else can say. Larry
I do
Gary Smyth
but to hear them explain there is much prep. The desired image needs to be redone with much thinner lines, the new image scanned and sized. The item and the laser need to be registered on the table and THEN it can be cut. Cut time is seconds, set up is over one hour, plus computer time. Estimate is well over $100. I don't want to eat that and the guy who owns it probably won't either. It's an alternative that would do the job but $$$$. It can almost certainly do it better than what I can do with my hands.
Angle grinder...
John in NM
From the sound of it, the job won't be worth the cost of a bi-metal blade. And even that is going to dull quick cutting stainless.
I'd use some kind of rotary tool, either an angle grinder or dremel, or anything in between, and a cut off wheel. Follow up with files.
On the other hand, if this is a paying job you are quite justified in walking away from it due to the misidentified material.
Keith Newton
I would try a metal blade in my bosch jigsaw before buying a bandsaw blade. If bi-metal won't cut it, I'll bet you can find one with either carbide granduals that will cut it.
If that doesn't work. Find someone with a plasma arc cutter. I would bet that most welding shops have a hand held version of that.
Gary Smyth
Keith. The pictures are twice the size of the real thing. Would a hand held plasma cutter be able to get the accuracy that small of a working area? I know that the CNC controllers will do the job, but some of the curves stop pretty abruptly and working the cutter in such a small space by humans seems like a risk. I don't know, just asking.
craigd
craigd
I would/do use a 32 tpi hacksaw and cut by hand (24 tpi would also work).
Then files; round/rat tail/chainsaw, flat, triangular (used saw file) and maybe a round needle file.
You need to be pretty aggressive with stainless so that you take a deeper cut than you might normally, light cuts just work harden the surface and make life miserable. The other trick is to put the work in a solid vise close to where you are working it (less than 1/4" exposed) so that you can press hard without the piece moving or squealing.
Ditto what John said  Angle grinder cutoff wheel
I have done that sort of thing in the past using my drill press and an angle grinder cuttoff wheel. Had to jury rig a bushing for the Arbor to fit the cut off wheel but that's wasn't too hard.
Thomas S Stockton
Gary
I think a plasma would be a little inaccurate and a angle grinder or dremel would be my choice
Tom
CNC Milling Machine
Ok...perhaps overkill. Just trying to help you justify buying one. ;-)
Keith Newton
Yes, I think so. Of course that may depend on the user, whom you should ask, and maybe see samples of their work.
There is a lady artist in my area who does lots more intricate work than that.
Unlike a cutting torch where the handle is about a foot away from a really hot flame, the hand-set is about the size of a snub- pistol, so your grip is in pretty close to the action.
I'll bet you can find someone good by asking at a local welder supply. They will know who is good in your area.
I wish
Laser cut
Lucio Carrozzo
I think the easiest is to have it laser cut. it is a simple process very accurate and with no room for error or injury.
Re: Laser cut
Lucio Carrozzo
In addition to laser you could also consider water jet cutting, same process as laser except the one is done by light beam and the other by concentrated water jet. I am sure either will solve your problem very easy.
Dick Coers
Bi metal blade will work, but you'll not be able to cut it at wood blade speed. A little coolant spritzed on will help also. Not sure about the count, but I suspect at least 14TPI, probably more. Isn't the rule 2 teeth in constant contact? That would be 16.
