I got this mystery board in a bundle of soft maple. It's gray in the middle but white on each side. I'm wondering how it got that way and, what kind of wood it is. Here's a detail of the end :
The white was on all sides. I have planed off the top and bottom to expose the gray middle.
This shot shows the true color (my crummy camera sometimes is prone to make some shots yellow) :
Here's the grain. Refer to the above pic for the actual color.
Dale, what would cause the blue staining and why only on the inside and not the outer surfaces of the board ? Do you think it may have been subjected so some kind of chemical in the kiln ?
Yes. It is a about as heavy as hard maple, maybe a little bit heavier.
I do have some rough sawn persimmon I can open up and compare. Unfortunately, it's buried under a pretty big stack. Maybe I can pull out a board that may not be too wedged in.
very similar. It is not as heavy as Hard maple however. I would bet that the board was cut from a small tree with sapwood on each edge of the board causing the color difference.
I'm pretty sure it is Persimmon too. When you first cut into it, it is light beige. As it dries on the outside first, that layer gets set. Yet on the inside, where getting the moisture out of a really dense wood is slow, the blue-stain as Dale described it, gets started.
Persimmon is almost all sapwood, which has really low decay resistance, and blue-stian is incipient decay. One thing I have found interesting about this wood, is that in from some injuries I've seen, the black stain from the sap oxidizing, formed a V, with the bottom of the V at the injury, and the pith between the ends, which is not like most other woods, like Oak, where moisture moving in and out across the grain, would be radially.
Of the few persimmon's boards I've seen, none where stained. Persimmon has grain with the ~~~~~ curly marks, like long wavy hair. Hackberry and holly are two woods that are bad to blue stain: If ADing, do so during cool weather, or put the air to it to get the shell of the lumber dry.
