Cradle in Walnut,Walnut Veneer and Hickory
Alan Young
Alan Young
Our fourth grandchild arrived a little over a week ago-But before I could finish this cradle. H-26 1/2",W-28 1/4,L-33". I searched a while for different cradle designs-then took elements I liked and came up with this design.
If I make any more I'll probably alter the width as 28 1/4 is plenty wide-my daughter likes it though because she thinks our granddaughter can be here longer. I don't recall the radius of the rockers but that will get adjusted too-It seemed to rock well in development stages but in the final edition it flattens out sooner than I would like-I may remake the rockers at some point.-Alan
Re: Cradle in Walnut,Walnut Veneer and Hickory
mark valsi
Nice job, I like the design !
Larry in nw ohio
As Mark said Very good design, also good lumber picking. For our 3 children I just went right to the baby bed, they are in the shop shots. They went from simple to more and more difficult, at least for me. Larry
Needs a mobile
Well, there you go, kicking out another great heirloom. Now you need to make a mobile for it...hey, just sayin' ;-)
T.
Very Nicely Done
Care to tell how you made the legs? Stacked? Routed? Dadoes? All of same? :D
BTW
Howcome the bead along to the top of only one end?
Alan Young
The legs
Alan Young
are 1.5" square. I cut the recessed sections on the table saw with the miter gauge. First cut the bevels with blade at 45. Then hogged out the waste sectios with a dado...
Alan Young
Dear Sherlock!!
Alan Young
Only noticed it myself after it was glued-I was distracted by other things during this build-Thought I had run all the grooves but I hadn't...Grandad becoming forgetful.
I Was Close
My guess was dado for the hogging and then a bench chisel for the bevels. ;)
