Bandsaw speed
Bandsaw speed
Bandsaw speed
Larry in nw ohio
I have an old craftsman bandsaw that works for me very well. I`m having trouble fixing the band speed. I have a digital speed meter and I`m coming up with 300 srpm`s reading on the blade. I think it should be around 2000. Am I doing this wrong, should I be reading this on the wheel or some place else. Thank you Larry
Re: Bandsaw speed
Re: Bandsaw speed
Richard McComas
Around 3000.
http://www.highlandwoodworking.com/woodworking-tips-1205may/askthestaff.html
http://forums.finewoodworking.com/fine-woodworking-knots/power-tools-and-machinery/band-saw-blade-speed
Re: Bandsaw speed
Re: Bandsaw speed
Larry in nw ohio
Richard I think I understand the speed thing. I don`t understand where do you take the speed reading, off the blade or the drive blade wheel, you``ll get a different reading off one or the other. Thank You Larry
Re: Bandsaw speed
Re: Bandsaw speed
del schisler
larry go here and put in the rpm of motor and pulley size and and inside wheele size and it will give you the blade speed, it should be around 3,000 on my delta i am about their which is good enough del
http://vintagemachinery.org/math/sfpm.aspx
Re: Bandsaw speed
Re: Bandsaw speed
Lee Schierer McKean, PA
Normally you would measure the RPM;s of the wheels and knowing the diameter, calculate the inches per minute that the blade is moving. I don't think your digital meter is going to read the speed of the blade by looking at the blade itself.
A 14 inch wheel travels about 44 inched each revolution. So a speed of 75 rpm's would equal about 3300 inches per minute.
Lee
Re: Bandsaw speed
Re: Bandsaw speed
TomD
or if you do have a 14 inch wheel, that is pretty close to a 3.5 foot circumference, so just multiply your wheel rpm by 3.5, or even 3 to get your SFPM. Using inches just requires you to revert to feet again.
I got an industrial bandsaw book at one time, and it had SFPM rates for cutting donuts in it. There is a different speed for everything, close is good enough. Or all you are going to get. The rest can be adjusted for by feed.
Re: Bandsaw speed
Re: Bandsaw speed
Altizer
If you are looking for speed in fpm and you have a 93.5" blade. When you do the math, at 300 rpm you get 2,337.5 fpm. Not sure if that is what you are looking for in this case.
If it is a 105" blade, 2625 fpm.
Re: Bandsaw speed
Re: Bandsaw speed
Jason Waters
How does the length of the blade affect the speed?
Even if you put a Riser block and longer blade, your bandsaw is still moving the same fpm, at least in theory (there could be some small loss I guess).
Jason
Re: Bandsaw speed
Re: Bandsaw speed
Larry in nw ohio
Thank you Altizer, that is what I`m after, but my blade is only 80" and the motor runs 1750 with a 1.5" motor pulley to a 5" driven pulley on the bottom 12" wheel. Would you mind figure figureing that out, I`d like to see if my 50year old math is the same as todays. Thank you Larry
Re: Bandsaw speed
Jim DeLaney, Austintown, Ohio
Re: Bandsaw speed
Larry,
I make it 1649.34 feet per minute - a bit slower than I'd prefer. I'd put a 2½" pulley on the motor to get 2748.89 fpm, which is close to optimum for cutting most woods.
Re: Bandsaw speed
1625 sfpm
del schisler
this is it ,if you measured the outside dia of pulley's , like was mention a 2.5" pulley will get you 2708 sfpm aprox
Re: Bandsaw speed
Re: Bandsaw speed
Larry in nw ohio
Jimand Del Thanks that is what I get also. Thanks everyone, since I got good answers for this, how about one more. What speed would be good to cut 3/8-1/2" aluminum. Thanks again. Larry
Re: Bandsaw speed
Re: Bandsaw speed
I'd take the speed down some more - maybe a 6 or 7" driven pulley - and use a blade intended for metal cutting, like a ½" blade with 10~14 teeth per inch.
Use a lubricant intended for aluminum, too. It'll work well, but it'll also get messy and require quite a clean-up before you cut wood again.
Re: Bandsaw speed
Re: Bandsaw speed
Altizer
I was basing my calculation on the OP info:
If we are measuring blade rpm then blade length matters. With an 80" blade we get 80 x 300 rpm = 24000 inches per min. Or 2000 fpm.
If we are using wheel rpm then you are correct the blade speed will not change reguardless of length.
Re: Bandsaw speed
Re: Bandsaw speed
Jason Waters
Got it. I see your calc.
I would have measured the bottom wheel with no blade (for safety). Guess I would not have thought to measure the blade. I don't know how I missed he was measuring at the table after rereading.
Of course, I still one of those little Starrett things with a wheel that measures speed (or really distance), and you have to do some math. Someone gave it to me, so that's what I have. Never needs batteries.
Jason
Re: Bandsaw speed
Re: Bandsaw speed
Altizer
Hopefully it was a non-contact measurement on the blade. It would almost have to be.
I use the same type tach at home as you do.
At work we can use either strobe lights or photo tachs to make non-contact measurements.
