Computer advice?
Computer advice?
Computer advice?
I am usually pretty self-sufficient when it comes to computer stuff, but I hsve a problem that I don't know how to fix. I got some coffee into my laptop keyboard yeaserday and now it is all screwed up. I suspect that the moisture in there is shorting everything out. Should I try using warm air to try to dry things out? Or what?
Thanks for any advice.
Re: Computer advice?
JMOHNIKE
Yes warm air or just a fan, 90% of the time they recover with no problems.
Good luck
Chuck in mtl.
i read somewhere that if you place the electronic item in a bag of rice that the rice will soak up all the extra moisture. someone has a cellphaone fall in the water and after a time in a bag of rice it worked afterwards.
If the above doesn't work ...
Mike Farinella
You can get a new Logitech K120 keyboard for around ~$20 at Wal-Mart.
Jason Roehl in Lafayette, IN
Google!
Specifically, do a Google search on your model of laptop for disassembly instructions. Keyboards are generally pretty simple, durable items, so what might work is to remove the keyboard (probably some combo of screws and prying it out from under some tabs, maybe have to remove a plastic piece of trim first), then rinse the keyboard out under running water, then blow it out with some compressed air, and set it in front of a fan for a while.
Jason
Sorry
Mike Farinella
I missed the part about the laptop.
del schisler
if it were mine i would have use air compreser and blower on the key board tell no more coffee came out, than covered up the screen with a thick towel to keep sun off screen, and than set it out in the sun for a while, that will dry it , if maybe sugar was in the coffee , it may left some stickkey sub. in the pad's, and than it will have to be taken apart and clean under the pad's which make's the contact's , it like a compreasion contact, i have cleaned many remote's with contact cleaner and than wiped dry , but the key board will have to be taken off for that tho ? good luck
Thanks for the advice, folks
So far nothing has worked, but hope springs eternal.
Ellis, may not be the coffee shorting the keyboard. My sister had a similar problem a few years ago. After much hair pulling, I finally found that one key had "stuck down" causing all kinds of issues - wouldn't boot etc. Most keyboard on laptops are pretty well sealed so a stuck key may be your problem. Takes a little searching to find - then real simple to fix!
Re: Thanks for the advice, folks
Buy some electronic spray cleaner. It comes in an aerosol. It will hopefully displace any water or residue. It evaporates pretty quickly.
De-ionized water
Chuck in Mtl.
I have heard of deionized water being used to clean electronics, and specifically sugary substances that make things stick. I can provide no guarantee as to the results but it will work and after dry with compressed dry nitrogen is the best.
Did you try calling GeekSquad?
Galen Vetterick
This was the death to more keyboards in the office I worked. I imagine laptops are even tougher to clean. The dry coffee residue conducts so on the fine printed circuits it gave all kinds of odd outputs. At least a keyboard was cheap to replace. Not sure how difficult it would be to disassemble and clean a laptop keyboard section. Just be sure you photo the keyboard so when all the keys fall out you know where they belong! :D
Good luck!
At least I am not a coffee drinker and maybe you will kick the habit if you have to replace the laptop. ;)
Re: De-ionized water
Kurt
That would be my thought too - distilled or deionized water then put it in the sun or in front of a fan. Replacing a keyboard isn't too expensive; it's what's underneath the keyboard e.g. the mother board that can get spendy. And it goes without saying to unplug and remove the battery before doing anything with water.
