OT - 1972 Chevy pickup turn signal replacement
1972 Chevrolet pickup truck. Replacing turn signal switch. Got the old one out; cut the wires so I could feed the new one in. Now trying to place the switch itself inside a housing that, as best I can tell, is exactly the right size for the switch, but doesn't allow any play to wiggle it into place. Anyone done this who has some advice? I'm going to have to go refill my curse bucket. Spent most of the afternoon just trying to get the danged thing in place.
Re: OT - 1972 Chevy pickup turn signal replacement
Mark Nowicki
Sorry I can't help you Bill, in 1972 I wasn't old enough to drive.
The 1972 is not a typo??
Some pictures please.
Mark
No, they were making trucks in 1972. This is an intermittently used heavy loads vehicle. A friend borrowed it, and, when he brought it back, I was spotting him backing it up the driveway when I realized the brake lights weren't working. Diagnosis led to a decision to try replacing the turn signal switch - the brake circuit runs through it.
Jack Guzman from Maine
Bill,
I have done this.
I had a 1970 that I inherited from my uncle the mechanic. Still had the bill of sale in the glove box.He paid $1200 or $2400 dollars for it new.I forget which. It's been a long time.
My memory isn't so hot but I seem to remember having to disassemble part of the steering column and unbolt it from the dash to get the harness out. You have to remove the lever from the switch. I don't recall having any problem fitting it in though.If you still can't get it describe it better and it may jog my fuzzy memory.I have a Haynes from that year and a Chilton's but they don't describe the process.
I wish I had your problem.I miss that truck.---Jack
Well, I gave up
went to a local garage where the mechanic struggled for half an hour getting it in. Then I drove it carefully back home (no brake lights, no turn signals; back streets), made the electrical connections, and found out there was a short between the electrical contacts and one of the springs that serve to orient the turn signal switch block for right/center/left. It happened only on right turns, and I discovered the contacts were a bit long - remnant extra length from the assembly process, I think. Fifteen minutes of working the springs off so I could reach in with needle nose pliers and wiggle the extra bits off.
The brake lights/turn signals work now, joy; two errands in the truck today. The only bad part is the hazard lights built into the switch don't want to work; that's a project for another day.
Re: Well, I gave up
Bill, congrats on getting it fixed. I couldn't help but I sympathize. I owned a 71 model of that truck for many years. In a wood working related note, I loaned it to a neighbors kid who made it about two miles before rear ending somebody and damaging the grill. Could not find a replacement so I built on out of treated wood. Cut a bunch of lattice like strips and made a grill and painted it flat black. Looked better than you might think and served well for several years. I miss that truck, hang onto yours.
