Weathering cedar instantly - my experience
Tim Greif - West of Chicago
I've read about taking cedar boards and making them look weathered using a vinegar and steel wool solution, so I figured I'd give it a try. I wanted to make of couple of craft style wall displays for some artsy-fartsy stuff and have it look like it was crafted from weathered wood.
I put a small chunk of fine steel wool (000) in a cup of white vinegar and let it steep for about four days. I diluted the "tea" about 3:1 with water. I tried a few different dilutions to see what the results were. Stronger solutions (less water) produced darker results that I didn't like. Perhaps if you only let the "tea" steep for a day, you may not need to dilute it as much. My final solution was about 1/4-cup tea diluted to one cup of solution. The pictures below show the results. I even put the board on the neighbor's 15 year old fence for comparison. You could easily use this on replacement fence pickets or deck boards to blend it into the weathered wood.
Worked for me.
