Spraying with Lacquer
Joseph Prendergast
Was perusing your article on 11. Lacquer, did not read the whole thing, but noted your comments on water base lacquer. Although water base lacquer doesn't have the characteristics of of nitrocellulose lacquer, nor behaves the same relative to climate conditions, it has come a long way to matching the qualities of nitro. lac......it no longer looks like a plastic finish on a piece of wood. If you look at some of the better water base lacquers, the are more than adequate for most any wood project in todays world, and except for antique restoration, are almost indistinguishable. Have used both products for too many years and will not go back to nitro lac. except for small projects, pieces that need rubbing out, antiques and or musical instruments to name a few. If you come into my shop, you will never go back to nitro lac. IMHO. Joseph ......ps. most people would never be able to tell the difference. I know, your a pro but most aren't.
