Double Top Table Pull Out Runners
Don Stephan
Interesting in building a table with pull out runners. The upper and lower top will be 36" square and hinged on one edge. With the top "closed" the table can serve as a card table or breakfast table. With the runners pulled out 18-22" on opposite sides the top will be slid sideways 18" and then the upper top "opened" to make a 72" x 36" table top for occasional need.
Obviously, notching opposite apron rails for the runners will weaken them, and I've never built this type of table. Any tips, guidelines, and experiences would be greatly appreciated.
Re: Double Top Table Pull Out Runners
Dutch pull out table
Merle
Don, if I am understanding you correctly and if you have access to FWW issue #7, IIRC, Tage Frid walked through the process of how he made a similar piece. I recently made one and put UHMW tape on the bottom of the top piece, but Frid used felt strips applied with contact cement. The aprons were 4" wide and 7/8" thick so I don't think the notches for the slides would create a problem. He tells you how to determine and cut the angle on the slides. I would say that ensuring that the slides are attached at the same and correct angle is the absolutely critical step. Unfortunately, I was under time constraints and didn't take any pictures. HTH
