Report on pin nailer
About a year ago I needed a pin nailer for a project. Only needed to drive about a dozen pins so I did not want to spend a bunch of money. I bought a cheap one form Harbor Freight. I think it was about $30. In the mean time I have used it a few times and I amen a very few. Today a friend asked me to help him install crown molding around the top of kitchen cabinets. The molding was maple and prefinished. Pretty hard maple. The cheap little gun worked flawlessly. The pins were an inch long. They held much better than I expected. We had to move a filler strip after it was nailed it was pretty tough to get it off. The holes left were so small they did not need filling. Almost invisible from the floor.
The point is that I did not spend much money and got a useful addition to my nail gun arsenal. I am sure an expensive version would be better, but for ten times as much money it should be. The only thing I don't like about the gun is it does not have a safety. Still would not hesitate to buy it again.
Re: Report on pin nailer
Bruce, a MN Galoot
I've had a HF pin nailer for 6-8 years, except I paid $20 for it. It came highly recommended, especially, as you say, for the money. This week I used it to nail down the perimeter of some 3/4" oak flooring with 2" trim nails. It's a real life saver for nail baseboard, saving lots of wear and tear on the old knees. No jams, no hesitation, it worked really well. Especially for the money.
Bruce I think these are two different nailers. Mine shoots pins that are 23 gauge, I think, (about the size of a straight pin with no head) and I'm thinking yours is an 18 gauge model. Mine will only shoot nails up to about an inch long. I also have other guns that will shoot brads and finishing nails and I use them on base and other stuff.
Glomming on. 23 Gauge, I Like mine a lot
Gary Smyth
About a year ago I did the reviews and ended up buying a Grex 23 gauge. To be sure it wasn't $20 but I bit the bullet. The total w pins was hovering $130, I'm sure of that. I purposely didn't risk the Harbor Freight as I was going to use it heavy for about three weeks and didn't want to bbog down at mid stream. Mine runs 3/8" to 1 3/8" pins (but I've only tried longer size 1" into walnut.) If you don't have one look into a 23 gauge pin gun as your next purchase. I use it for jigs, mouldings and frames, holding stuff while glue sets. The pins almost disappear from view and mine has even worked fine using a one lunger no tank car tire compressor. I bet it would work fine short time with a portable air tank too. I found the pins to be relatively expensive, but I use this tool much more than I thought I would. In tight quarters I find that the safety trigger is a challenge but what are you going to do? I'd use it more if managing the compressor hose wasn't such a pain. The tool itself is a workhorse with no reliability fears..
Bob
Bob
I bought a Senco years ago and love it I paid over a hundred for it and it was worth ever penny, it does have a safety.
Jim Hoeller
I bought a $100 pneumatic flooring nailer at H-F in November that uses staples and nails. I used it to install about 15,000 staples (also from H-F). Had a few jams when a staple hit a nail in the sub-floor. The jams were fast and easy to clear. It came with tools and a plate to install 1/2" flooring and a decent instruction book. Worth every penny and then some.
