gloss black finish
gloss black finish
Jack Guzman from Maine
gloss black finish
I just replaced a broken piece on an Ethan Allen Boston Rocker.The new piece needs to be painted to match the rest of the chair. The chair is painted gloss black.The finish is high gloss that I don't think I can get straight out of a can of black latex enamel from the local hardware store.The finish on the arms looks alot like a piano finish.
Anyone have any idea what they used on this chair for a finish?Any ideas on how to get that look?
I emailed ethan allen and they said they would try to find an answer for me but I haven't heard back from them yet.---Jack
Re: gloss black finish
Mark Nowicki
Try a hobby shop. Gloss Black is a very popular color in model building. Humbrol paints has it in enamel, Tamiya in acrylic, also available in 180ml (6 oz.?) spray cans.
Mark
As I recall most piano finishes were Black lacquer. Obviously you can rub lacquer out to a very high gloss. Others with more experience may chime in with better responses, but if it were me I would use lacquer.
Bill Tindall, E.TN.
Solvent based Kilz, sand to glass smooth then gloss solvent based enamel paint. Can overcoat with clear finish if desired. If you can't spray use aerosol cans. I do picture frames this way and they turn out shiny black.
The factory likely used black lacquer.
John Veerkamp
Furniture may be lacquer. It is readily available in spray cans in gloss black.
One more for lacquer. Back in the day a friend and I ran a cabinet shop. We did gloss black mirror frames with lights built in. We sprayed with flat black lacquer and then clear coated with gloss. I think Bill has a good idea with the Kilz. Should do a good job hiding the grain. Do a test piece first to be sure everything cures as it should. I suppose if you had to you could coat the Kilz with Bin. Its basically shellac and should serve as a seal coat.
Kilz
I'm going to try Bill's formula. Sounds right to me.Thanks folks---Jack
del schisler
their is a product called piano lacquer here is the link i used to use piano lack yrs ago now that was real black gloss , but this google search will get you ideas http://www.google.com/#sclient=psy-ab&hl=en&q=piano+lacquer&oq=piano+lack&gs_l=hp.1.1.0j0i22i10i30j0i22i30l2.0.0.1.9082.0.0.0.0.0.0.0.0..0.0...0.0...1c..12.psy-ab.2xYniCsNpLU&pbx=1&bav=on.2,or.&bvm=bv.45960087,d.dmQ&fp=57f367f5584558ff&biw=990&bih=542
Ralph Lipeles
Should you need repairs again they may be available directly from Ethan Allen. Some years back I was brought a chair with a broken leg. I considered making a stepped dowel or turning a new leg. I then went to Ethan Allen to discuss how to get the black finish to match the rest of the chair. I was surprised when I was told that Ethan Allen sells prefinished repair parts and at reasonable prices.
Ralph Lipeles
Gary Smyth
Here is a picture tutorial with some video for modifying a METAL computer case to a mirror black finish. Not cheap with time, but the results speak with the final picture of the tutorial. For fifteen minutes of viewing this may help. When you get to the linked page click "TUTORIAL GUIDE" (in red). You may have to temporarily allow pop-ups. Click "next page" for six pages total. This will get you there for deep gloss reflective finish but is it worth the time for a fingerprint magnet? Try other suggestions volunteered here first.
http://www.mnpctech.com/case-mod-paint-computer-pc-case-mod-how-to.html
Jim Hoeller
I made a statue base that required a gloss black finish. It was a struggle until I asked another wood worker who had repaired pianos. He said think "automotive" not wood. Start with a primer that fills the grain and sand it smooth. Then use black laquer and build up light coats. Buff between coats and then polish to desired luster. I bought the primer and laquer at a paint shop that specialized in auto finishes.
I'm going to contact them. Thanks Ralph---Jack
yape
Another idea. Sand to very smooth, rub in India ink, let dry and reapply to desired intensity. The apply two or three coats of clear gloss water base Varathane. I did this with oak on a project and it turned out very well.
