Teak table finish
Teak table finish
Teak table finish
Joe Pack
My son and daughter-in-law just bought a teak table and chair for their patio. The teak seems to be untreated; a water drop does not bead, but soaks in. They want to put a finish on it to prevent spotting, but I don't think they want to mess with spar varnish or other film surface. What would you suggest using to reduce spotting on the teak surface?
Thanks.
Re: Teak table finish
John Veerkamp
Teak needs no finish to last forever exposed to the weather, It will silver in the ultraviolet light. Nothing will really stop it. If they object to the water soaking appearance, regular waxing will slow that some, but exposed to the sun or in hot weather it will soften and can soak into the clothes of a sitter.
Finishing outdoor stuff = maintenance...
John in NM
Now if they are ok with that, any thin drying oil will produce decent results. Out here I'd have to recoat maybe 4 times a year with most, less with some others. Where you live may be different, less sun and more atmosphere improves matters a lot.
I would probably look for some Penofin. I found it worked about as well as anything on ipe, so it should work for teak as well. I would suggest you avoid film finishes.
Several years ago, I made my mom a teak cutting board out of a left over piece. Since it gets no UV to speak of, it still looks fine with no finish at all and gets daily use and washing.
