ADVERTISE HERE - FREE TRIAL
Spray Painting Help
Spray Painting Help
John Pierce
Spray Painting Help
John Pierce
I recently bought an HVLP sprayer and made notes on all the comments and am having a problem. Everyone said that I should be able to spray Polyeurathane out of the can. I checked the viscosity at 10-12 seconds. However, there was no info about how to adjust the spray. After my first spray, I had a very uneven finish as of there were large drops of spray interspersed with very fine spay droplets. In my second attempt I adjusted the spray so it went from nothing to what appeared to be a full spray, which was about one or two full turns on the adjustment, much restricted from my first attempt. The problem is I am not using a colored paint and as such cannot see the result even on a sample piece. Does anyone have suggestions about how to set the spray up. I do not plan to spray again until I get some advice.
Thanks, John
Re: Spray Painting Help
Bill Tindall, E.TN.
It is too thick to spray with conventional gun. I thin it 1 part mineral spirits or naptha to 3 parts varnish....approx. Only brief experience with HVLP gun, didn't like it and returned to conventional which is easier to use.
Lights and more lights for good spraying
Dick Coers
If you are having trouble seeing how the spray pattern is going on the work, you need more light, and more light, and more light. Put the work between you and the light, so when the liquid goes on, the light reflects into it. Sometimes you have to rotate yourself around, so the light is constantly reflected on the wet finish. Poly is next to impossible to spray. If you can get it thin enough to go through your gun, it will run off horizontal work like crazy. It's not the thinning that will get you, it will run on stuff right out of the can too. It flashes off so slowly, it just runs off the work if you get just a tiny bit too much on the work. Flat spraying only if you want it to work.
John Pierce
Re: Lights and more lights for good spraying
John Pierce
Dick, If I understand, you are recommend I spray with the piece horizontal. I have lights reflecting on the work pierce, but have have the work pieces vertical. So you are recommending changing to horizontal and thinning the poly?
John
Bill Tindall, E.TN.
If you are laying on such a heavy coat that you need to have the surface horizontal you are spraying too heavy a coat. I spray enamel paint and varnish regularly and have no problem doing so. Pick a hot day so it will dry dust free quickly. But the good lighting is essential. if you are new to spraying practice on a piece of cardboard spraying water. When you can get an even coat of water without runs you will be ready to move to varnish or paint.
I find it harder to spray a horizontal surface. For something like a drawer I will spray vertical then move to horizontal for drying.
Jason Roehl in Lafayette, IN
On thinning...
Test, test, test.
One misconception I often run into is that people think thinning something 1:1 with an appropriate thinner will make the finish "half" as thick. That's not the case at all. Generally, 5% can be adequate, and 10-15% would be a "soft" maximum.
Jason
John Pierce
Re: On thinning...
John Pierce
I was thinking that the viscosity test would tell me that the poly was ok without thinning. But your advice of using water is a good one. That does not mean any clean-up. I just have to make sure that I can hang the cardboard up vertical during the spraying and not get messed up by the air flow from the HVLP gun.
Spraying w water
Gary Smyth
is a good idea because you can set the spray pattern and judge ideal distance coming off the gun too. Remember though that once you get the hang with water, the viscosity of the final finish will probably change from water. There will be experimentation required there too but you should be able to control the gun much better.
John Pierce
Re:  Spraying w water
John Pierce
I have tried water this morning. The viscosity is about 5 seconds with water using the cup Rockler supplied. Should I simply dilute my poly to that viscosity for spraying my pieces?
John Pierce
Re: no
John Pierce
Then would the 5-10% dilution be appropriate? Or would I shoot for a viscosity range?
John
sugggestion
Bill Tindall, E.TN.
One approach would be to read what I wrote in my first reply and try that. I use this rule of thumb whether spraying or brushing. You must realize that products now days are formulated to pass EPA muster for volatiles, not for best performance. Another suggestion would be to spray a piece of cardboard or other scrap to see that all is well before doing the furniture.
Viscosity, as someone else mentioned is not a linear function of concentration, which is to say a 1:1 dilution will reduce viscosity by more than 50%, maybe much more. How much depends on the finish. Cellulose based lacquers are particularly sensitive.
John Pierce
Re: sugggestion
John Pierce
Well, after spraying on cardboard with water, I used the 15-10% dilution suggestion for the poly and tried it on cardboard also By this time I had anchored the work to prevent it from rotating. All went well. I even sprayed my cherry desktop which I had spared from all the failure attemps. All went well. Now for a second coat in my garage tomorrow while the bugs and the weather cooperate. I am no master, but your tips have moved me forward from being a clutz. Thanks so much for the help. This is the first time that I have sprayed anything.
John
Dick Coers
I've probably sprayed over a hundred gallon of clear. Lacquer, conversion varnish, and precat lacquer. All of them are so easy compared to poly. I don't care how careful you are, you will get a run somewhere if you are spraying vertical surfaces. It just flashes off too slowly. Somewhere you are going to slow around a corner, hit the surface with a bit too much overlap, etc.... Just saying if you have to have it horizontal or you are spraying too heavy simplifies it a little too much. It's not easy to spray!
Any lighting suggestions?
GolfSteve in Calgary
I use the spray booth pictured below. I have overhead fluorescents and several mobile halogens. I can get the spray area very bright, but have never found the combination of lights that lets me see how wet I am spraying .
I usually shut off the overhead fluorescents and have a very bright (2x300 watt) halogen diagonally on one side, and a much less bright (1x150 watt) halogen diagonally on the other side. The work area is bright but I am really just spraying blind because I cannot see the wet surface as it develops.
As for spraying poly, I've never done it. This guitar is the first time I've used regular old toxic, smelly lacquer and the stuff is an absolute joy to spray compared to shellac and waterbased lacquer. Sprays beautifully, doesn't want to run on vertical surfaces, and dries instantly. It's hard to screw up! I thinned the lacquer about 1 part thinner to 4 parts lacquer. 12 seconds through a DIN4 cup. I tried both a 0.8 mm and 1.2 mm nozzle (for a SATA IV minijet HVLP), both atomized well. I used the 0.8 mm and had to spray fairly slow or the coat was too dry. If I used the 1.2 I had to be careful not to slow down anywhere or I could "almost" get a run on the vertical surfaces. If I was more experienced the 1.2 would have been the correct nozzle to use.
My biggest mistakes was resting my thumb on the fan nozzle adjustment knob. I inadvertently reduced the fan width as I was spraying several times. I finally realized what was happening and had to retrain my thumb rest elsewhere.
Re: Any lighting suggestions?
Bill Tindall, E.TN.
I spray outside. I angle that to be sprayed relative to the sun to get the wet reflection . In spray booths the light is on the sides and I think that is where I position the sun. What I have seen in a home made arrangementsis a 4' fluorescent on the floor mounted vertical to the floor and on the sides of the target.
