Did you know (TS) ? . . .
Steve Mackay
Been having a bit of bind between my TS blade and fence lately. Adjusted the fence, checked the blade angle, then noticed the table insert. By Golly, that thing has four adjustment screws in it ! Well, well, well. Just when you thought you were smarter than the average bear . . . .
Re: Did you know (TS) ? . . .
Discovery Is A Good Thing
Steve I make my own inserts and of course add the set screws. what I do is adjust the 2 rear ones so the insert is just few thousandths higher than the table. Flush would be perfect but I find that occasionally you get the board when on edge that wants to hit the rear of the insert slot. Usually this is when ripping thin stock. Leaving it just a hair up has stopped that and I haven't seen any problems with doing it.
Jesper, Denmark
Jesper, Denmark
Slightly chamfering the insert will cure that.
