gunk on wood floors
gunk on wood floors
gunk on wood floors
Liz
The builder who installed my wood floors as part of a major build, allowed some kind of gunk to harden in large areas. He refuses to fix this and I have been unable to remove it using goo gone or Bono. The Bono seems to help a little but would take a very long time and much pressure on my hands and knees to do this. Short of having the whole thing refinished, how can I remove this. I would like to pursue this legally but the cost is prohibitive.
I'm not sure what exactly the "gunk" is but think it most likely is glue or grout or whatever the other subs were using to install tile etc. The flooring is engineered mahogany over hot water radiant heat.
Thanks
Liz M
Re: gunk on wood floors
JMOHNIKE
Liz, I don't know what state you live in, but most states have a contractors license board or some other type of licenseing agency. You may be able to contact them to get some sort of satisfaction from them. Good luck.
Yonak
Liz, I agree with JOHNMIKE : the contractor must fix this if he did it. Don't pay him if he doesn't. At the very least he should tell you what the gunk is so you can research how to remove it.
Dave Bair
Many states have a small-claims court where the parties represent themselves and attorneys are forbidden. Document your claim with photos and some of the gunk. Sometimes the threat of a suit will get the cooperation you're looking for.
agree
Bill Tindall, E.TN.
that would be the way to go here in TN.
Do not attempt to remove this stuff until you know what it is. There is a good chance that a solvent could mess up the finish on the wood, either soften it or dull it.
Hal
Agree with all the above. Go to your contractor's board and go to small claims court. I once had a dispute with an RV dealer over money they owed me and were trying weasel out of it. As soon as I filed the claim, the money came thru pronto. They had no desire to go to court, and I would suspect neither does your contractor. The cost to file here in AZ was $25, and the effort to complete a form and state my case was little. Good luck! Hal
"The builder who installed my wood floors as part of a major build"
Liz,
If your floors were part of as much larger project, they may be covered under a performance bond that a contractor must (usually) post with a bank, lender, or contract beneficiary. Such bond, usually in the area of 10% or more of the contract price of the work, is either posted or held back pending satisfactory completion of all phases of the job.
In this situation you can contact the bank/bond-holder and notify them of the claim. They will then either require the contractor to correct the problem or send in a remediation company to clean and restore your floor to its proper condition and will deduct the costs from the original contractor. You must, however, act quickly, before the money is disbursed or the bond is released.
