A55 Smoothing Plane
Shopsmith help
Shopsmith help
Shopsmith help
Lester Gillett Independence Mo
I have a Joint-Matic from shopsmith and the instruction for the
Dovetail corner joint said how to set it up with there Dovetail
bit, but if you use a bit from outher co that you will have to make
servial adjustment to git it wright. Is there any one here that has
this ShopSmith and dou you use outhers bits and how do you
set it up. I would not want to spend to much time in setting it or
wast some wood doing it.
Lester
Re: Shopsmith help
Re: Shopsmith help
Ralph Lipeles
Lester,
There is a very active Yahoo Shopsmith group that can probably help. It is the User Group, not the Maintenance Group.
Ralph Lipeles
