Veritas - Innovation in Tools
Finishing Tips For African Mahogany?
Mark Meier (Ann Arbor, MI)
Anyone have experience finishing African Mahogany?
I'm working with it for the first time and it's quite beautiful - chatoyant - but very challenging to mill. The grain is very interlocked. I actually had to panel sand starting at (gulp) 40 grit to remove the tearout from planing. I've taken it up to 120 now, and it's starting to look pretty good. But I'm wondering if the pours need to be filled prior to finish or what might work best.
Mark
Re: Finishing Tips For African Mahogany?
African mahogany (usually one or another species of khaya) finishes nicely with everything I've ever put on it -- lacquer, varnish, oil, etc. Whatever finish is appropriate for your project should turn out fine with no surprises. Pore filling is unrelated to the "which finish?" question. The question is do you need a filled finish or not. Pore filling is essential if you want a mirror finish. Depending on the species you're working with, the pores could be either large, medium or small, and you might want to use a little bit of filler to take care of the longer or deeper pores. I suggest getting some paste filler and the appropriate oil-based pigments and trying it out on some test pieces to get a feel for what it looks like and how it relates to the final finish you intend to put on it. Be sure to let the filler dry completely before proceeding.
Jesse Cloud
Ellis nailed it. One more thing to try: the open grain on African Mahogany will absorb pigment way differently from the tighter grain. Try a glue size (10 parts water to 1 part yellow glue) rubbed on a scrap. Let it dry, lightly sand to remove raised grain, then apply your favorite finish.
Here is what it can look like
Bill Tindall, E.TN.
yellow dye stain, brown dye stain, oil, shellac
In contrast to Bill's example
Bruce, a MN Galoot
this is what it looks like with just Minwax Antique Oil finish, no stain, applied with 400/600 W/D sandpaper, 3 coats. It wasn't filled, but I'm sure the application with sandpaper filled the pores a bit. The stuff is a bear to plane, requires a very sharp blade.
Thanks for the advice everyone, I appreciate it.
Mark
Re: In contrast to Bill's example
Color looks great. I won't be staining mine either.
Mark
Two tips
Mark Hennebury
1. Try Potassium Dichromate on Mahogany, i used it years ago, seemed to do a nice job.
2. I think you need to improve your milling if you have to go to 40 grit ( that's road gravel)
Larry
How can one get the Dark color found on antiques?
Thanks, Larry
DO NOT USE CHROMATE
Bill Tindall, E.TN.
There are two good reasons.
Physical health- it is a known carcinogen by inhalation. Not this CA crap where everything is known to the state of CA, but this stuff really is. It raises the grain so the next step is sanding. The dust will contain the dichromate. Breathe dust and you expose yourself to cancer risk. Dye stains can achieve the same color and the dye stain color is more permanent.
Financial Health- It use, storage and disposal are highly regulated in some states. If you have a neighbor that doesn't like the sound of your woodworking machines and she learns you are using it she could make life exceeding unpleasant.
Re: Two tips
Regarding the milling... Yes, 40 grit is nuts. However, in my "defense"... I had it jointed and planed at the sawmill. I just had to cleanup the resulting tearout. Maybe their knives were really dull. I took a spokeshave to some of it today and it shaped quite cleanly.
Mark
Tip three; always get a second opinion
Mark Hennebury
Listen to Bill for the Dichromate
I am like the Keith Richards of woodworking and do many things that shouldn't be done.
I used it years ago and it works fine, but Bill is probable the sensible voice of reason here.
As regard the milling; that's a pretty crude finish and most planers should give you a pretty good finish, with little sanding needed. Makes your life a lot easier. So look for someone with a better planer.
