Brake problem, 2011 Rav 4
Wendy Ostgaard
I have a 2011 Rav 4 with 25,000 miles on it. The brakes are worn so thin that metal is hitting metal, and the drum is badly scored. It looks like the brake apparatus is on full time, which is why the pads are gone with such low milage. I have been telling the dealership that the Mileage I am getting is miserably low, but they claimed nothing was wrong. In addition, the alignment, which is so bad it can not be repaired (there is no kit), is causing uneven wear on my tires. I bought this car for its supposed realibility, and I think it is a lemon. (there were multiple other problems which the dealership fixed)
Re: Brake problem, 2011 Rav 4
Chuck in mtl.
can you find a good alignment and brake specialist in you area? 25,000 miles for the front brake pads sounds fairly normal and is linked to the kind of driving you do. If you are a heavy braker then expect then expect them to wear more quickly. The wheel alignment sounds very fishy. If is really a misalignment then is should be adjustable however if something in the suspension is bent or broken then a good alignment place can find this for you. it sounds like the dealer is just trying to get rid of you.
Hoa in Alameda
Disclaimer: I don't have an all-wheel drive car so this is not my direct experience.
The traction control (or anti slip) system uses ABS to regulate wheel spinning. If the system thinks a wheel is slipping, it will apply friction to the wheel. A friend of mine for whatever reason had different tire sizes installed to her AWD car, thus the wheels turned at different speeds. The system thought a wheel was slipping and continuously applied the brake, leading to premature brake failure.
You stated your vehicle had an alignment problem. That problem may cause excessive wear on the brake.
Galen Vetterick
I assume you mean the discs are badly scored as the RAV4 has front disc brakes not drums. I imagine the dealer has given you some reasoning for your reported conditions. They use "soft" pads so they do wear rapidly depending on your driving habbits. The disc got scored only due to not replacing the pads before you had metal to metal contact. Are you a left foot driver with an automatic transmission? Many people who are forget they are putting pressure on the brake peddle while going down the road causing the brakes to drag more. Even long coasting stops or jack rabbit stops add to additional pad wear.
The Honda CRV also has "soft" pads and do not last over 25000 for a lot of drivers so the RAV4 is right in there too.
Have they explained your front tire wear pattern? You did not say if the center tread is wearing faster possibly due to overinflation or both outer edges evenly worn for underinflation. Is the outer tread cupped? Is only the outer tread worn. I see that a lot on hard cornering or even scuffing when slow speed overstearing. A lot of original equipment tires are soft rubber compounds and are not high milage tires so they do wear out faster. A good mechanic should be able to drive with you and by checking out your car define where the problems are. Impossible to define by an internet mechanic. ;)
