Finish for Ipe
Larry
Does anyone know of a good Exterior Finish for Ipe?
Thanks,
Finish for Ipe
Larry
Thanks,
Nothing
Part of its allure is that you let it weather in. You start putting stuff on it and it'll look like crap in 2 years and then you get to strip sand and refinish it.
I second that
Bob
Leave it alone and let it age. In a few years mix 1 part white primer to twenty parts mineral spirits (or less) and spray it on it will turn a silvery white.
Tend to agree
I have an ipe floor on our veranda that I installed about eight years ago. I tried a couple different finishing products, including a Benjamin Moore deck stain/finish product, and when that didn't ever dry, I stripped it and tried Cabot's Australian Timber Oil, and that didn't dry either. So, I figured that ipe is one of those woods like the rosewoods that don't allow oil-based finishing products to dry. I could be wrong on that, but twice bit, three times shy. I'm living with the natural gray of the weathered wood, and it isn't so bad. Ipe is very dense and hard, and it takes a long time for it to waste away.
It comes pre-finished all the way through.
Keith Newton
if you don't like it after a year or two, then dilute some bleach, spray it, then give it a light sanding, and rinse. It will look like new.
how do you want it to look next year
Bill Tindall, E.TN.
The decks of the bridges on the VA Creeper bike trail are Ipe. After a bit they bleached to a dull light color. In this state they will last a very long time. If you like this look do nothing. If you want to keep the brown color you will need finish.
Re: Finish for Ipe
NickinMass
I built an ipe deck on our previous house, and finished it with Cabot's Australian Oil. It looked great right after the finish went on, but in the end I wish I hadn't - needed to be reapplied annually to areas that got a lot of sun/traffic, and built up in areas that didn't. Ipe is so dense that the oil barely penetrates, and you have to be diligent about wiping up excess.
If I had to do it again, I would leave it unfinished and give it an occasional gentle power wash.
The Atlantic City boardwalk....
Howard Acheson
.... was constructed over 100 years ago using unfinished Ipe. It's still going strong.
Re: The Atlantic City boardwalk....
Dave Bair
Thought Sandy trashed it; could be wrong, though.
I've used two with "acceptable" results...
John in NM
Sikkens SRD, and Penofin.
At my elevation (7,000 feet, lots of desert sun) the UV is strong enough to require recoat of either product every 6 months to keep a finished look. Depending on your local conditions, you may get a longer span. Neither one seems to form a film (assuming directions are followed) so there is minimal prep work before re-coating. Even so, we eventually went with the weathered look.
No finish will penetrate it
Lee Schierer McKean, PA
About four years ago, the company I worked for did some testing of outdoor finishes on IPE. What we found is that no finish will penetrate into the wood. All of them remain on the surface. The wood is so dense nothing can get in. We would apply a finish and then cross cut the wood. We never saw any penetration.
Lee
