Hitachi MV12 diagnosis
Terry Alexander
My Hitachi MV12 has been on the "fritz" for a couple of months now. I can't complain....it's had miles of board through it (table mounted). Lately, if it stops, I can gently tap the bit and it will eventually get going again. Original thoughts here was that it was the on/off switch. Not sure about that with the tapping on the armature making it work. I took it apart and there is some scarring on the armature. The brushes look good (at least 1/2" left on them), but I don't know if 1/2" is acceptable.
Should I invest the $15 or so (brushes are cheap...but shipping is what kills me) and see if that cures the problem...or should I just put my hand over my heart....say a few words and look for a new router?
As always....your valued input is greatly appreciated.
Terry Alexander in West (as in Abilene....not the town) Texas.
Re: Hitachi MV12 diagnosis
Mark Hennebury
My guess would be the speed control; that's what went on mine.
It was too expensive to replace so i just removed it and have been using the router for the past ten years with just the on/ off switch. It runs at the high speed but its better than throwing it out.
Terry Alexander
Can you tell me how to remove/bypass the speed control switch?
Thanks in advance!
Mark Hennebury
Hi,
So, i removed the variable speed control and tied the white wire to the green with a marret and stuffed it in the housing.
" border="0" alt="">
Jesse Cloud
"Scarring on the armature" sounds suspicious. Are the springs that push the brushes onto the armature still attached to the brushes?
Terry Alexander
Thank you so much. The info and accompanying photos is VERY helpful.
Terry Alexander
Keith Newton
Terry, I think I would go on and order the new brushes, and see if you can get a Tommy-stick to dress the commutator. That is a little frayable dressing stick, that you touch against the commutator, while the motor is running. The little grip particles dress both the brushes and commutator like new, and will increase the power, eliminate arcing, and get it back good as new. If you still have a problem after that, then do what Mark suggest. 1/2" is not very much brush length.
Jason Waters
I haven't looked at the brushes in the MV12, but could it be they are the self limiting type and aren't coming out car enough to reliably contact the armature? That would causing arcing and such.
A lot of new tools in the last 15-20 years have these types of brushes.
Terry Alexander
After putting in a new switch....guess what? It WAS the speed control!
I thank you so much for your response and the pics. It made my job much easier. So I now have new brushes, a new on/off switch. Hopefully I will get another 15 years services out of it!
Again,
Thanks so much.
Terry Alexander in West Texas
