Need Help with TS Adjustments
JERRY DRAPER
Situation: Delta 10" Contractors saw with Unifence and Pals alignment system.
I have never been able to make perfectly square crosscuts. The rear edge which is against the miter gauge fence or sled fence is always square. The front edge is always open about 1/32". The blade is within .001 parallel to the miter slot. The fence is within .002 front to rear but is .006 concave in the middle. All measurements are in relation to the left miter slot and measured with a dial caliper. Will the deflection in the middle of the fence cause this variation or am I overlooking something?
Re: Need Help with TS Adjustments
Jesse Cloud
Check along your fence with a square in the vertical position. Delta has a history of making fences that aren't square. Your fence may be only 0.006 concave at one height, but much more so elsewhere.
Also, if you are using a splitter, check to make sure it is dead in line with the blade.
Just to rule out technique, set up a feather board and use a push stick and see if the variance changes.
Don Stephan
When making a perpendicular cut on the TS, I don't use the fence in that way. A short piece of wood is clamped to the fence several inches back from the blade as a stop. The stock is held against the miter gauge, slid over against the stop, and then moved through the blade without anything touching the right end of the stock. This way it doesn't matter if the fence is bowed, and the cutoff can't be bound between the blade and fence.
You might joint very straight one edge of a board, rip the other side closely parallel, and use this to test how square the miter gauge is cutting. The wider this test piece the better. Place it against the miter fence with about half the piece to the right of the blade, with the fence completely out of the way. Crosscut the piece. Flip the offcut front to back so that the leading edge during the cut is now the back edge. Bring the two cut pieces together with the back edges against a very straight surface. If the two ends do not match perfectly the cut was not square.
Which fence?
Lee Schierer McKean, PA
Hopefully you are saying that your miter gauge fence is out of flat by .006 and you are not using your miter gauge in combination with your rip fence to make cross cuts. If so this is very dangerous.
I doubt your miter gauge fence being out of flat has anything to do with the situation you are seeing. If the fence were the cause, then the entire cut should be out of square. It sounds to me like you have slop between the miter slot and the miter gauge bar. With your dial indicator mounted on your miter gauge and the tip against the blade, try moving you miter gauge left and right. How much movement do you see in the dial indicator?
As you make the cross cut are you moving the piece of stock left? If the miter gauge fence is slick, you can attach some self stick sand paper to it to help keep the wood from sliding.
Lee
JERRY DRAPER
Thanks Jesse, I'll check all of those.
Re: Which fence?
JERRY DRAPER
The Unifence is concave .006 not the miter gauge fence. I have checked the blade as you suggested and the variance is .001. I thought my problem might be that Unifence variation was not ripping cuts parallel. Thus the cross cut would be square to one side but not the other side. However, measurements of ripped boards seem to be parallel. I am not cross cutting with the end of the boards against the Unifence.
Keith Newton
Jerry, I'm thinking that you may be getting some vibration, which induces the blade to cut a wider kerf in the beginning, which gets dampened as it gets into the cut. You can check that by starting into a cut, then turning off before finishing. You could then test with a fine tapered wedge.
Cross cutting with a miter gauge is really tough. First there has to be some space between bar and slot, to keep from jamming. I tried peening one of my bars once, but that turned out to be a horrible mistake that wasted a lot of time to correct. Then, even if you get everything perfect on a short piece, then try cross-cutting a long piece, the added table drag, where it leaves the edge of the top, will pull all the slot tolerance to one side.
Even with a tightly built, perfectly adjusted sled, you can get a little variation from hand position and center of effort while feeding. But that is just something you have to figure out.
One thing that I think helps when truing up a TS, is to have the blade all the way up, then examine the tooth marks on the both edges of the kerf. If the back of the blade is cutting on it's way up, on one side of the kerf, it will be more pronounced, than if it were set low.
And, one of the most important things, is to do all your setup with a good quality perfectly sharp blade. Any dulling, or missing tips, will cause the blade to cut toward the path of least resistance, which will deflect the blade plate, especially tilted.
JERRY DRAPER
Thanks Keith. The splitter was not in line with the blade and that correction helped a lot. I had not thought about blade vibration or the possibility of it cutting on the way up. I will check that also.
