shop floor
CharlesP
I plan to put plywood on the concrete of my 20'x30' shop. What would happen if I put styrofoam insulation 4x8' stuff under the plywood. Would it give way under the weight of a tablesaw or bandsaw?
Cold floors make my feet hurt.
shop floor
CharlesP
Re: shop floor
Jack Guzman from Maine
I converted my garage to a shop. I laid down 2" x4'x8' polyisocyanurate(foil backed insulation board).I duct taped the seams.On top of this I laid strapping every 16" on center then screwed down 3/4" advantec 4'x8' tongue and groove floor panels.This is basically osb designed for flooring applications.I have had a contractors saw,5" jointer and other heavy tools on it with no crushing or deflection.Been like this for years.I also have split green wood on this floor for chairmaking. It is solid.---Jack
Re: shop floor
As Jack said probably not. There are some other products that also work well.
One is "Hushboard". Another is "QuietBrace". They are sound deadening sheathing products. They are sheathing - but they do have some R value. They are also tougher than the foam. I've used them under plywood subfloors to deaden sound - but they also help keep the cold out and the heat in. Typically runs $8-11 a sheet. If they don't crush under those large entertainment centers, I figure they won't crush under a table saw or a jointer.
Re: shop floor
Its common practice to put insulation under the perimeter of a slab floor. Some areas are starting to build highways on top of blocks of EPS foam to reduce freeze thaw damage. They claim the foam will support about 60 pounds per square inch. I'm not sure about that, but if you put plywood over it it will handily support most anything you would have in your shop.
I would use extruded polystyrene or the foil faced stuff to help suppress any moisture.
EPS beneath roads
Yonak
I'm sure the engineers know, but I don't understand putting insulation beneath roads. I believe it's contact to the ground that provides warmth. That's why bridges freeze before roads on solid ground.
Maybe the idea is to keep the roads frozen more, but I can't imagine that would reduce the number of freeze / thaw cycles.
Just wondering.
Re: EPS beneath roads
Me too! I saw this on some show about what's new in road building. I can't figure what the point is, but they insisted the roads were lasting longer. They were using blocks of it that appeared to be a foot or more thick.
OTOH, there was the road they built on shredded tires. In a effort to make use of old tires they shredded thousands of them and then used them to fill in a depression. They were several (Many) feet thick. After a while they noticed that this stretch of road did not ice up and the snow melted off quickly. Then they noticed steam or was it smoke coming out of the cracks. Then it was on fire. Turns out the steel cords were rusting from the water leaking in. Rusting produces heat. Then fire. My understanding is they couldn't put it out and just let it burn.
No freezin on that road
but it must have made for exciting commutes.
Puts a whole new spin
Merle
on burnin' up the highway.
And on what it means to have a hot car
