I am working on a house I bought at a tax sale. It has the worst amateur workmanship I have ever seen. I won't go into the list of defects, but it never ceases to amaze me. My question is how to level the corner of a room that seems to "droop" a bit. There is an area drops about 3/4" over a distance of five feet.
I want to put the kitchen in this area. Any suggestions of what to do? The flooring there now is OSB nailed to the joists. What do I do to fill in from nothing to 3/4"?
Barry, I had a similar situation in my own home. A lot depends on what your final floor is going to be.
As has been said if the "sag" is due to insufficient foundation or something that can be corrected underneath the existing floor that is the best "fix". In my case it was not that situation - just a 100+ year old home which had settled on a great foundation and large beams.
If it is not something you can easily correct then there are various methods of disguising the problem. If you are going to install a laminate or "floating" floor, you can use leveling compound (what I did). This is available in two versions, a thick trowel-able version and a self leveling version. I actually used both as I had some areas over 3/4" low and some far less. I then installed a free floating floor (with foam under liner) and have had no issues for over 10 years.
If you are intending to install a carpet, vinyl or tile floor it probably would require a bit more work whereby you shim the low areas (or use the leveling compound) and install a new "top" floor. if you use the leveling compound you could probably get by using a thin plywood or OSB - glued and nailed to the existing floor and compound.
