Good solution!
John in NM
My drill press has some sliding rings on the mast, one is clamped just under the head so that I can do exactly what you have done, without having to hold the head up while I tighten the clamp screw. Though a bench model, mine is still quite heavy.
I also often turn the table to vertical and clamp jigs to it, as you have done to the work bench. If the drill press is leveled, re-setting the table is quite easy. Mine is on wheels and a bit out of level, so I have used the level on an adjustable square, and sometimes even a dial indicator to re-set the table. The deluxe route would be to have two tables! Though perhaps the mast isn't tall enough for that.
