Just as we were getting ready to print our tax return our HP printer died. So we replaced it with a HP 8600.My question is when we go to print something say driving direction from Google Map as we get ready to print it askes Color or B&W. Even if we choose B&W we still get coloron the map. This happens in other print jobs also. Am I missing something?
MAybe a "duh!" question, but did you run the new setup disk? If yes, then you might be able to check through the preferences tab and correct this. Hope this helps...I am definitely NOT a computer/printer guru.
call the tec. support that is free and they will get it right, i replaced my printer and desk top comp. and if i had a question i just called them, good support. get the number from probly the back of the book .
Sometimes you need to go deeper into the print options (a job or two ago, the printers were set up that you had to specify color vs. b&w in both that first printer dialog box and also down in the advanced options or something like that). I'd poke around a little to see if there is an additional color/b&w check box.
