Thinking of getting a Track Saw but
Gerald
is a Track Saw just dedicated to one purpose (running on a track)? Can it be used for rough cutting 2x lumber and other cutting jobs (off the track)?
I know very little about using a Track Saw. I know they are great for panel work, but that is not what I do all the time.
I do not want to spend heavy cash for a dedicated single purpose saw.
I am not sure about which one to get, although Festool is at the top of the list.
Is Amazon the best place to buy?
I appreciate your input.
Thanks,
Gerald
Re: Thinking of getting a Track Saw but
Bob Boswood
I bought a festool track saw for one reason. My back and shoulders wont allow me to safely hump 3/4 ply through my table saw anymore. I use it mostly for cutting up panels hen doing cabinet work. I suppose you could use it for framing but you can buy a used worm drive for 50-100 bucks all day long. Craigslist has them always. Just my 2 cents. Also my festool performs flawlessly.
Gerald
Bob, I can certainly relate to back and shoulder pain when working sheet material. One of the reasons for looking into a Track Saw.
I did not mean that I wanted to use a Track saw for framing, I worded it incorrectly. I crosscut 8 to 10 foot lumber 4 to 12 inches wide at times. Can a Track Saw be used for doing that kind of work, off the track.
I also looked at the Festool table, but sticker shock stopped that idea.
Gerald
Jesse Cloud
A track saw can cut "off the track" but you loose all the advantages of a track saw, no particular advantage on accuracy, same chance of kickback as a regular saw, etc. I would not try a plunge cut off track - way too dangerous.
As said above, pick up a cheap skill saw at a yard sale for off track use.
The advantage of the table is that you get dead square cuts without having to square the track every time.
I haven't lifted a sheet of ply or mdf since I got my track saw, just put sawhorses at the back of the truck, slide the pieces onto the horses and go to town. And these saws are made with dust control in mind, your lungs will thank you.
Mark Nowicki
A track saw is pretty useless without the track, but it can easily rip and crosscut wood with one.
Grizzly sells one, there is no need to be raped by Festool.
http://www.grizzly.com/products/Track-Saw/T10687
Re: Grizzly Track Saw
Gerald
Thanks for the link Mark.
Wow, Grizzly has a Track Saw Master Pack. It includes the saw, track and some accessories, all for less than half of the Festool price.
I wonder how the dust collection would compare to the Festool. Dust collection is key for me.
Gerald
Mark Nowicki
I have a Festool saw and vac combination, and the dust collection is nothing special, definitely not worth the price that I paid for it.
The Grizzly will probably be just as good with a regular ShopVac. If you really want to splurge get Fein with a auto start feature.
I repeat (thanks for the opportunity) there is no need to consider a Festool product.
Mark
Jim DeLaney, Austintown, Ohio
I have the Festool 55 Track saw. It's essentially a 6½" saw, and on the guide will cut thru a 2X4 with maybe an eighth of an inch to spare. Off the guide, you gain about another quarter inch of cutting depth.
You can use the FS55 off the guide just like any other circular saw, but the plunge action takes a little getting used to - especially if you've been using a 'regular' saw for fifty years prior.
You can also get a rip fence - like on a regular circular saw - for the Festool, and it works very well. Like all things Festool, it's kinda pricey, though.
The bigger Festool 75 has greater cutting depth, and is maybe a bit more powerful, but it's also quite heavy - and much more expensive. My local (regional, I guess) Festool Rep told me NOT to get the 75, since the 55 would do everything I'd need, except maybe cutting fence posts. :)
Hope this helps you make your decision.
Jesse Cloud
The picture of the Grizzly looks almost exactly like the Festool saw, even down to the color of the parts. The Festool patent expired recently and there have been lots of copies out there. Bottom line is that Festool is made in Germany and I suspect the Grizzly is made somewhere in Asia as cheaply as they can get it.
I recently broke down 5 sheets of mdf with my Festool TS55 and when I swept up, I had maybe a teaspoon of dust on the floor. Seemed pretty special to me...
C. John Hebert
You've got to be kidding. I have the festool and vac and have used it in clients home's with very little or no dust at all. Love my festool!
Track saws are generally plunger cutting and is rather difficult to use for rough cutting. They were designed primarily for sheet goods and straight edge cutting on rough lumber rather than joining on a jointer. I have a Makita for rough cuts...and my festool for sheet goods
Mark Nowicki
Indirectly, you are the reason that I bought a track saw. I saw your review of one on the Oak and I have always respected your opinion and admired your work.
I like my Festool as well, and I do use it inside. However, even you will probably admit that the dust collected will depend on the type of cutting.
Thankfully, Festool is no longer the only game in town.
Mark
C. John Hebert
Sorry...but mine works absolutely flawless as far as dust collection. It really shows up best even with pine, and sanding. Maybe the vac you bought was to small. I have the ct22e and that maybe the difference. I also don't use the disposable bags...not that it makes any difference. I'm not promoting Festool...but use it all the time
