slate
art demers
I broke a piece of slate I won't be able to replace it so can I glue together?
slate
art demers
I've done it...
John in NM
Both with 5 min epoxy and tinted marine epoxy (the white paste, not West
System or similar). The one's I've glued were fresh breaks not a crack filled with clay. A lot of the inexpensive slate I've seen the last few years has those cracks. If there is clay in the crack it won't glue - though one could carefully clean out all the clay and use a really tough epoxy to fill the gap, something like West System in that case.
Stone must be handled very carefully from then on, the joint is not as strong as the rock was. I've done this on tiles that had lots of trimming to a funny shape that we didn't want to repeat. Epoxy was only to hold it together until the tile was set.
Re: slate
Frank Orfanello
I too have repaired a piece.
As John said, the repair is not as strong as the original piece, but in my case it's held for over 10 years on a table.
I used an epoxy I got from Home Depot, I cleaned the break well, and clamped the sides until the repair was dry.
I'm not an expert so as they say YMMV.
Re: slate
art demers
Thanks I tried it this morning it seems to hold I used titibond epoxe we will see . Again thanks I can always count on you guy's
