Need an Idea
Need an Idea
Need an Idea
Bob Boswood
Sometime ago I made an end grain top for a kitchen island. 36x52. Everything fine until a crack developed recently. It is 2 1/2 inches thick. I used west epoxy. Must have missed some areas with the epoxy. My solution is to add threaded rod on both ends and regluing onsite. Need an idea on how to through drill a 3/8th or larger hole 36 inches long and have them align properly in the midle. As I said I would like to do this on site if possible. It was not a paying job, just for a friend but I still can't not fix it if you know what I mean. I dont usually have to deal with failures but it should be fixable with no problems. Any ideas would be appreciated.
Bob
Re: Need an Idea
Re: Need an Idea
Keith Newton
You probably ought to drill the first 6" or so from each end, then use your router to cut a deep groove in the middle, then cap that back over after the rod it in.
However, that may not be the end of your problem. If they get the board really wet, it will expand against the nuts on each end hard enough to crush the wood under the washer. This will then leave the bolts loose, so as it dries later, a new check can form, unless it gets tightened again. But then the cycle of crushing will start again everytime it gets wet.
Let them know, that they just can't ever let it get very wet.
Re: Need an Idea
Re: Need an Idea
pecker
I think you would have better success using countertop draw bolts.
You would need to get to the underside and route some mortises for them.
One brand is Zipbolt:
http://www.mcfeelys.com/product/FSC-2600/Zipbolt
Re: Need an Idea
Couple thoughts on this
If it split, it was a contraction problem. I'm wondering if the top might have been anchored on the sides without enough allowance for shrinkage. If so, my idea is to glue the split back together and then release any constraints that will make it happen again. It could be a fix a s simple as using some figure-eight washers or Z-clips.
Ellis Walentine, Host
Re: Need an Idea
Re: Couple thoughts on this
Lars Parrington
i'd also guess it's a shrinkage/contraction problem. the threaded rod sounds like a bandaid that will just lead to more problems.
i had a stack of end grain cutting boards sitting in my house this winter. cracks developed along the periphery of two of them. i'm fairly sure the cracking was caused by the periphery drying out and shrinking while the center of the boards was prevented from drying out due to being in a stack.
i would guess that in your case either the end grain piece is overly constrained as ellis suggested, or it is mounted on a base that is trapping some humidity under the center.
if so, removing the constraint or humidity differential should cause the crack to close back up and become virtually invisible all on its own. if you want to get some glue in there, you might use a slow setting epoxy and wet the area around the crack so that the wood swells and the crack closes up before the glue sets.
Re: Need an Idea
Re: Need an Idea
Dick Coers
You may have gotten enough epoxy in there, but then used too much clamp pressure. Epoxy likes a thick joint. I'm also not a fan of throwing steel at a wood movement problem. It will very likely be a temporary solution. Summers a comin', the crack will likely close. I bet Ellis hit the problem with the restraint issue.
Re: Need an Idea
Re: Need an Idea
Bob Boswood
Thanks all. Think Ill reglue the top, then reattach with those table top figure 8 thingamajigs. Way easier than what I was thinking for sure.
Re: Need an Idea
Re: Need an Idea
Was the bottom finished the same as the top? I do this on all my table tops so the moisture it picks up stays the same. Mostly I do this to keep them from warping but if it's picking up moisture from underneath and is bolted down so it can't move it can open up a crack.
Re: Need an Idea
AllThread & Tension Rod Nut *LINK*
charlie belden
Lee Valley may have your solution - their "Tension Rod Nut" (see link below)
As someone else suggested - drill a hole the diameter ofthe "neck" of the Tension Rod Nut a bit deeper than the "neck" is long. In THAT hole, using a drill bit a little over the diameter of your AllThread, drill in 3 or 4".
Do this on both sides of the table. Cut the AllThread to a length that will permit a bit over HALF the depth of thread in the Tension Rod Nut. Put a Tension Rod Nut on one end of the AllThread, leaving it loose by a turn or two, and run the AllThread through the table. Thread the other Tension Rod Nut onto the end of the AllThread and tighten both Tension Rod Nuts with the steel Tomy Bar that you should order with the Nut order (get TWO - one for each Nut) until the crack closes.
If the table is in a cenrally heated and cooled environment it should remain fairly stabile. However, if it's in an envornment where the humidity varies a lot - periodically check the tension.
BTW - tape the two Tomy Bars to the underside of the table so you'll have them should you need them
LV Tension Rod Nut
