How to pull
Gary Smyth
a small press on bearing? This belongs to a Makita sander. I need to replace the shaft. For that to happen the pictured bearing needs to be pulled. Makita says it is a press on and should pry loose. Once off the path is clear to drop in a shaft. Problem is I can't get purchase underneath with even my smallest gear puller and no pry baror screwdriver has fit well enough to exert leverage to lift it. Wood wedges just crumble. I'm looking for ideas or a inexpensive tool. The bearing is 1/2" x 3/16". I'm replacing the shaft so damage there will not hurt. I'd like to save the bearing.
Thanks to all. Got the bearing off the spindle. Had to do a bit of judicious grinding on the puller hooks to get it underneath, and needed four hands and a vise because nothing wanted to stay in place when pressure was applied. The shaft on the spindle has a smaller diameter than the end of the screw on the puller (and the puller didn’t have a cone end) so a cut nail placed in the spindle hole gave me enough room to allow it to do the work. Thanks again.
