converting a unisaw 1.5hp motor from 115 volt to 2
Charles Jackson III
I been thinking converting my Unisaw 1.5hp motor from 115 volt to 220 volt, I am wondering how do you do that? I hear you get more hp with 220 volt current?
Charles Jackson III
Re: converting a unisaw 1.5hp motor from 115 volt
Bill Tindall, E.TN.
there will be a plate on the motor showing the wiring for 220. You may deliver more watts to the motor with 220 depending on the length of the wires from box to saw. Mine is 220 and it serves me fine.
Charles Jackson III
You have 1.5hp Unisaw as well?
walta
The only advantage you get from using 240 is you can run thinner, longer and cheaper wires from the panel to the saw.
Be aware most 1.5 HP Unisaw motors do not have an internal overload and if you change the voltage you will need the replace the overload heaters.
High or low voltage 1.5 horse power is 1.5 horse power.
Walta
Rick Christopherson
Do an internet search. Reconfiguring your motor to 240 volts will not give your motor more power. The only people that will tell you that is does are the ones that don't know.
During your search, if you see someone use the word "theory" in their argument, then run away. That is an internet codeword for someone talking about something that they don't understand. So they say it is "theory" when they actually mean it is just something over their head. There is no "theory" behind it. It is well known.
Bill Tindall, E.TN.
yes indeed, and I do not understand the need for a larger motor commonly bought unless one is doing production ripping of 8/4 lumber.
ripping 8/4 with 1.5 HP Unisaw
Bill Tindall, E.TN.
I don't do any production ripping with my saw but I do rip 50 bdft+/- quantities of 8/4 lumber like oak for individual projects, for example the recent oak work bench. Things go quicker with a blade with few teeth. Because I will be jointing edges anyway I do not fret the smoothness of cut when making cuttings from 8/4 lumber, hence, a blade with 8-20 teeth is satisfactory. I use an 8 tooth blade for thick ripping and it goes through 8/4 oak without hesitation. For 4/4 lumber the blade is immaterial. The motor never is lacking for this thickness.
For thick lumber I believe you will see an improvement wired for 220 if the motor is bogging down at 110 V. In any case it is cheap to try.
No difference in HP unless
As Bill mentioned, if you have either undersized wiring to your saw for the amp draw or a very long wiring run to the saw, it may appear that the saw is more powerful when wired for 240 Volt. Watts is Watts which is the actual "power" that any electrical motor, light or other appliance puts out. When you run a 120 Volt motor that take 10 amps to run, it is putting out 1200 Watts of power. When you run the same motor configured to run on 240 volts it will require 5 amps and will put out 1200 watts of power. The only reason the wire size and length becomes involved is that a larger wire is required to supply 10 amps than 5, so if the wire size is too long or too small the wire will have a voltage drop in the wire (it will heat up) and not supply a full 120 volts to the motor. When you wire the motor for 240 it only has to supply 1/2 the amperage so will maintain the voltage better.
Some numbers
Bill Howatt
The resistance of a 100' of #14 wire is 0.25 ohms. Note that the 100' is the amount of wire in a cable to a device 50' away from the panel because it is 50' to the device and 50' back.
If your saw is drawing 10A at 120V then it loses 10x0.25=2.5V along the wire which means the motor is seeing 117.5V or a 2.1% drop.
If you rewire to 240V, then 5A at 240V causes a drop of 5x0.25=1.25V which means the motor is seeing 238.75V or a 0.5% drop.
Now consider the case of a big 10 times running current initial start-up surge. The 120V circuit for a moment is dropping 25V so the motor is only seeing 95V and has considerably less power to get going. The 240V motor is losing 12.5V and will see 228.5V at the motor.
The above is a simplified version of all the factors in play but it does show why having larger supply wire (lower resistance) or reducing the current (240V operation) can help. It is also the reason that 240V operation may provide what appears to be a more powerful motor even if the motor itself isn't any more powerful when rewired to 240V.
Bill
I remember reading somewhere
Stuart Hough
that there was a manufacturer that did include an extra set of windings in their motor that came into play when the motor was wired for 220/240v. Don't remember which company, but there was a picture of the spec plate that did show an increased horsepower rating. If I recall correctly it was a 1.5 hp motor that rated 1.75 hp when converted. Not a big difference, but still a higher rating. In the interest of full disclosure, I have never seen one in real life, only in that magazine article.
more significant....
Bill Tindall, E.TN.
is when you do the calculation for the motor being loaded by ripping something thick and tough. As the motor rpm falls the current draw goes up. If there is any practical benefit from using 220V it will be important under situations where the motor is running overloaded, something easy to do ripping 8/4 hardwood with a 1.5 HP motor and a less than optimum rip blade.
I have one of those
Henry Higginbotham
Here's the motor plate on my Delta Contractor's Saw. Notice that the current draw at 230V is more than half the 115V (which would be the usual case), so maybe there's something to that rumor.
True that, Bill.
Re: I have one of those
Rick Christopherson
No that motor doesn't use different windings, nor does it make more power at 240 volts. The nameplate is simply derated for the 120 volt configuration to allow them to use a NEMA 5-15 (standard) plug on it. It is just the nameplate. There is nothing special about the motor.
This is well documented, and I even confirmed it directly (in person) with one of the project engineers for that saw.
Ah, finally
Henry Higginbotham
Some straightforward info on this motor. I'd heard the extra-windings story even before I bought this saw some years ago, but never really looked into it (I've had the saw for 8-10 years, but never assembled it).
But how did they get this derating past "the authorities"? It sounds like they've supplied a product which likely draws 17.2A at low voltage, but which they're suggesting the user can plug into a 15A circuit with 14 ga. wire.
Did I misinterpret something?
Re: Ah, finally
Rick Christopherson
A tablesaw motor will draw only what the operator demands of it. That is true whether you operate it above or below its rating. So regardless what the motor amperage rating, you can push any motor to the point of tripping the circuit breaker it is connected to.
There is also no concrete formula for what a motor should be rated. The manufacturer decides that based on whether they want to be aggressive or conservative.
Re: Ah, finally
Lars Parrington
i'm confused. are you saying you i could replace the 1.5hp motor on my tablesaw with a 0.5hp motor and as long as it was plugged into the same circuit, i wouldn't notice any difference? surely that's not the case.
Re: Ah, finally
Rick Christopherson
No that's not what I said. I said the actual rating on the motor is not an absolute. When the manufacturer rates a specific motor, there are several factors that can impact how high or low that rating may be. For example, some motor manufacturers choose to under rate their motors so that the motor is never intentionally operated too close to its point of damage.
