How to replace bearing on Jet Bandsaw wheel
Geoff in Madison
I figured out today that the strange squeak my bandsaw was making was due to a bad bearing on the upper wheel of my Jet 18" bandsaw. On this wheel there are two bearings on the wheel (one at the front and the other the back). The bad one is the one in the front.
What I am trying to figure out is how to remove and reinstall a bearing. The bearings are easy enough to buy. Behind each bearing is a retaining ring/ spring clip (R40 in size). I'm guessing that those just keep the bearing from sliding too far into the center of the wheel.
I can call Jet on Monday, but advice would be most appreciated.
Re: How to replace bearing on Jet Bandsaw wheel
Dick Coers
You don't have to be careful removing the old one, so you can probably go through the id of the back bearing with a long punch, and with a hammer, knock out the front bearing. Then use a socket or piece of pipe that will only apply pressure to the outer race, use a large vise or c clamp, and press the new bearing in. I've also turned a piece of white oak to the proper diameter as a ram to press in the bearing. It's a big deal that you not put any force on the inner race of the new bearing. That will cause damage. You might also consider putting the new bearing in the freezer for several hours to shrink it slightly. I didn't have to do that to replace bearings on the new Grizzly I was trying to rebuild. The clamp worked very well. Personally, if I had it all apart, I would replace the back bearing too. I can't imagine why the front bearing went bad, you must use it A LOT! I've gotten 25 years on my bandsaw without replacing them.
Update and advice on balancing a bandsaw wheel.
Geoff in Madison
Thanks for the advice.
While I would love to say that I used the bearings to death, apparently I was unfortunate enough to purchase a saw made on Friday afternoon right before quitting time.
I replaced both bearings yesterday and put the wheel back onto the saw shaft. One part of the wheel quickly rotated to the bottom. I put small magnets on the opposing rim until I got the heavy spot balanced out. It required 6.5 grams of weight to even the wheel out. No wonder the saw never ran very smoothly.
I called Jet and the rep said that, "I don't know how that wheel could have become so unbalanced"---likely, it was never balanced properly in the first place. The wheel is in perfect condition otherwise. I wouldn't think the new bearings would cause that imbalance.
The wheels are balanced by drilling out parts of the back side of the wheel. I know exactly where the heavy spot is. Should I try drilling it out (a little at a time, of course). A replacement wheel is $175 and I am reluctant to send Jet any more of my money (after the bandsaw, cabinet saw, and air filter). The new one might not be any better.
Re: Update and advice on balancing a bandsaw wheel
You have it balanced with a magnet - why bother drilling it out at all?
I might put a drop or two of epoxy and adjust the magnet weights.
It is always easier to add weight - because once you take it away - it is gone for good.
Bob Entwisle in NJ
How about a trip to your neighborhood tire place and see if they'll sell or give you a few adhesive wheel balancing weights that you can just stick on the wheel?
Bob in NJ
Dick Coers
Is it a spoke style wheel or holes in the casting? If a spoke style, you could get a u-bolt and clamp it around the spoke, adding washers as needed to get the weight. I bought a 19" Grizzly bandsaw last year, that had steel plates pop rivited to one side, and holes in the opposite side of the wheel. It still vibrated horribly. As I inspected the wheel, I found that the original casting was done so poorly that their was not enough material for cleanup, and the casting was not machined all around on the faces of the wheels. Rough casting on one side, machined on the other. I also found that the spokes were uneven thicknesses. I got a new wheel from them, and then found out the top wheel wasn't balanced properly either. I sent the saw back. It would walk anything left on the table off in less than a minute. It looked like those vibrating football games we had as a kid.
