I have a cheap B&D jig saw, a cordless circular saw and drill, some hand tools (hammer, screwdrivers) and not much else. I suspect that none of these are suitable for anything beyond rudimentary carpentry. I would like to dip my toes into some simple projects and don't want to mortgage the house to get started. Let's say, with a budget of $750 - $1000, what should I purchase first, second, third... just so that I don't get frustrated not having the proper tools? At this point, I'm overwhelmed with the options.
I started like this also. If you've never really goofed around with this stuff before, before you start the "real" spending, go down to Sears and get the bottom (or second from the bottom) Craftsman table saw. It's what I should have gotten first. Used to get 'em for $140-160. A table saw will do many, many things you didn't know it will do. And that one does rather well for the weekend warrior. You'll then find out just how far you want to get involved in this without a tweleve hundred machine sitting there if you change your mind and not really into this "woodworking thing". All the other machines and "upgrades can follow with your needs.
no point in just buying tools willy nilly. rather, decide what your first project will be, and then aquire the right tools for that job. after a few projects you'll have a good set of basic tools and the experience to know what you need next.
as for the actual buying, craigslist is your friend.
Good advice above. There are lots of "beginning woodwork" books around, probably some in your local library. Browse a few, pick a project or two that doesn't require lots of tools and give it a whirl.
Also, check out local Woodcraft store, adult ed or community colleges. Many have intro to woodworking classes where you can build skills and try the machines before you buy.
I started with about what you have. Then I got a Radial Arm Saw (RAS) (it was the rage tool of that long ago era and has since fallen in to disrepute, but I still have mine and like it)
One thing I learned form it was that I don't like multipurpose tools that you change from one operation to another. Some, like the RAS and perhaps the ShopSmith take forever (30 or 40 minutes) to change form one operation to the next. And, these tools may do one thing well, but they don't do everything as well as dedicated tools. I don't want to start an argument here, because there are plenty of people that love these machines and do beautiful work with them, but this was my personal opinion.
When I got a little money, I bought a table saw, drill press, jointer, and a shaper. Later I added a lunch box planer. Later still, a bandsaw. Looking back, the planer should have come sooner and the shaper could be deleted and use a router and router table instead.
I think the advice to start with the tablesaw was good. If I could afford it I would get a SawStop one. Another personal opinion. I also agree with the idea of figuring out what you want to do and then buy appropriate tools. And keeping an eye on Craig's list. Scan it frequently, good buys disappear in a hurry (Minutes or hours).
An enormous of amount of work can be done with a decent table saw and a good router and some ingenuity. The router is so basic that it's sort of like giving someone a pencil and package of paper and saying, "now you can write any book you want" to a person that does not know how to write.
Also, don't overlook hand tools. Almost anything you can do with power tools used to be done and still can be done with hand tools. There is a forum here for Handtools. Check under MessageBoards above and to the left.
i second the hand tool reccomendation. if you can manage to get a handsaw, a handplane, and a couple chisels into good condition, and learn how to get them sharp enough to shave with, then there will be very little you can't build.
if you can't use a handplane, then you'll need a power jointer pretty much from the get go, and you'll always be wanting a bigger one. however, if you become proficient with a handplane, you may never decide you need a jointer, and not having one won't slow you down much.
the handsaw will cross-cut lumber nearly as fast as a miter saw. combine it with the chisels and you'll be able to make both simple and complex joints.
you may be thinking "what power tools do i need in order to make furniture?". having a proficiency in hand tools will change that question to "which furnituremaking tasks would i like to speed up through the use of an appropriate power tool?"
the most common answers to the second question are:
1. long rip cuts, for which a tablesaw or bandsaw would be appropriate, although the circ saw and jig saw you already own could go a long way here.
2. initial flattening and squaring of lumber, for which a jointer and planer are the appropriate power tools, although i would consider the planer much more essential than the jointer here.
Although I had experience with power tools (good high school shop class) in the early days I did not have room for even one good big power tool. I did have a small clamp-to-the bench vice, carpenters saw, try square, hand plane, egg beater drill, couple chisels, sanding block, 4 1/2inch pipe clamps and a bench purposed to laundry in the rental we lived in. We saw a neat coffee table in the furniture store. Took the basic idea home, scaled out a table that had my interpretation of an improved design, bought a really nice ponderosa pine board, a nice fir 2X4 and a couple of 3/4inch dowels and went to work. Forty seven years later, that table is still the center piece of our house, and in my mind, the best piece of the 30 or so that I built later with power tools. Hand tools force attention to detail, consideration of grain structure, and show strengths and weaknesses of various joinery. They enforce efficiency in scheduling of construction steps and use of whatever tools you have. They also lead you to the type of tools you really need when it comes time to put up the big bucks for a trophy to place in the corner of your shop. Good luck which ever of the good advices you choose to follow. You'll likely really enjoy the trip and set your self up for a lifetime of enjoyment while producing useful items.
without using a good tape measure, combination square and caliper. Basic , but quality, marking and measuring tools are essential. Buy a book that will teach you how to use any power tools you buy if you don't have an experienced buddy to help educate you. Don't overlook the importance of dust collection, especially with power tools. Please ask any/all questions you have here and keep us posted with your progress.
Good of you all to provide this old newbie some guidance. I'm taking the slow approach and starting with a simple "I Can Do That" project only getting tools as I need them. Additionally, I have ordered a WorkMate bench to give me a place to work and I've gotten a combination saw and protractor guide to set blade angles. The project shouldn't take too long - I'll post a photo when I complete it. As I'm a working stiff, this probably won't happen tomorrow...
A planer makes the top surface of a board parallel to the bottom surface. If the bottom surface is warped, the top will be made parallel to the warp. In my opinion, it is very important to use flat and straight material to avoid incorporating extra stress in finished product. To me a planer is not very valuable without a jointer. Just my two cents.
Popular Woodworking has a regular feature titled "I Can Do That" describing projects with a limited set of tools. A list of expected power and hand tools is available and I believe a dvd for the inexperienced showing how to use the tools. If you could review back issues of the feature you'd get a sense of the capabilities and limitations of that tool set. Keep in mind that the joinery is not always sophisticated.
i agree that flat and straight is important, but i would argue that a jointer is not strictly required to get there.
here is a basic method which i use for any board that is wider than 6" (i have a 6" jointer). the rough jointing step usually takes me only a minute or two:
a coarsely set hand plane can be used to quickly take the high spots off of one face of a board (getting it flat, but not smooth). this face of the board is then used as the reference surface when the board is passed through the planer, thereby creating a flat and smooth surface on the other side of the board. then the board is flipped and run through the planer again to smooth out the original refence surface.
so, my point is that having a power planer but not a jointer only adds a few minutes to the prep time of each board. on the other hand, trying to do without a power planer adds a significant amount of work to prepping boards, even if you do have a jointer (because it is difficult to create parallel faces with it).
*note that i'm mainly talking about preparing rough sawn lumber here, although the same process would work for lumber that has warped since being professionally surfaced.
Look for a set of detailed plans for a simple piece that catches your interest.Get the tools recommended to finish the project.Keep it simple. You don't need a tablesaw or bandsaw. Those just make things easier.You can find plans at Woodcraft,Rockler or some other similar store. Big box stores have some plans sometimes and most woodworking magazines do.
Or better yet. Invest in some classes.I had a neighbor who inherited a big sum of money. He built a building and filled it with every woodworking machine you can imagine. As far as I know all he ever built were wooden knives.He ended up selling everything when he lost interest.---Jack
Avoid Craftsman, they do not offer the same excellent quality power tools as several decades ago. I agree with the table saw recommendation and would add get the best saw blade you can barely afford such as Forrest II Woodworker (no interest in Forrest). I've cut a lot of quarter sawn white oak in the past several years on my basic Delta Contractor table saw and the carbide teeth are still pristine.
I agree you do not need a jointer but it's ok with small jobs.
Here's what I like. It's kinda weird but it works like a charm. Using a board with straight edge, masking tape along the edges of the irregular edged board to the true edged board and run the true edged board along the table saw fence taking just a smidge off an edge of the untrue board. Now you have one straight edge on the untrue board with which to slide along the fence thereby trueing the other edge.
