Polishing a turd?
Polishing a turd?
Polishing a turd?
Edward in Vancouver
H.D. had a sell out sale on Ridgid 14" bandsaws, at $199.99 I couldn't pass it by. I don't do a lot of resawing, and when I do, it's mostly softwoods.
After 1 week I cracked the casting for the upper guide/pulley assembly when I tightened enough so it wouldn't slip.
I figured a new ridgid/jet/clone normally costs $4-$450, so my budget was $200 max on goodies. Got a Carter guide system, a link belt, and a couple of decent blades for it. In sweat equity I drilled a hole and installed a 2" dust port in the lower door, made a new alignment pin with a hole cross-drilled through the head to accept a chain so I wouldn't lose it again(...Doh!), and made a wood crank to slip on top of the tensioning handwheel so I don't have to flop my wrists so much when I de-tension it after use.
But the turd begs more spit and polish..........
In spite of the link belt, the whole machine shudders when I turn it off. During use it vibrates slightly, but not really an issue. The blade tracks well, and I can successfully resaw spruce 1 x6's into 3/8" slices fairly clean. With the belt off, the motor runs smooth and coasts a good 30 seconds after shutting down.
So, yes I need to balance the wheels. And I have been looking on line for tutorials. I won't go the route of drilling shallow holes into the rims, but am currently fooling around with pennies and masking tape.
Q:
Some tutorials say to remove the tires, and I'd rather not. What's the logic for removing the tires?
Can I remove the blade and belt, and balance the upper and lower wheel separately?
Any links or words of wisdom you can point me to?
Thanks
Edward
Re: Polishing a turd?
Mark Duginske - "Band Saw Handbook" - I like the book.
You can balance the pulleys without removing the tires and without the blade or belt attached. As you've put in this much work already - I guess your bearings are good - but you can easily check that when you remove the blade and belt.
Check Your Tires, Too
Robby Wright in San Marcos, CA
You might want to check your tires for out of round while you are at it. The lower wheel is easy - remove the blade, turn on the motor and "turn" the wheel using sandpaper or your preferred method. Please be careful so you don't lose a finger or worse. Rubber tires can frequently be thicker in some areas, thinner in others, and contribute to the out of balance condition.
Jesse Cloud
The lower and upper wheels need to be "coplanar", e.g. the vertical edges should line up. Low end bandsaws almost never come that way. Take a piece of ply (or whatever) with a straight edge hold it up to the wheels. The table will block it, so mark where the table is and use a jigsaw to make a cut out so you can get the ply to rest against the wheels. If they don't line up, shim one with a washer.
Same principle for pulleys being in line.
I bet if you google "bandsaw tuneup" you will find scads of how-to videos.
del schisler
wheel's don't have to coplaner, what this video on bandsaw tune up http://www.youtube.com/watch?v=wGbZqWac0jU&list=FLYDEiGLzvqQNIl-nqvD2OOQ&feature=mh_lolz
Brian from Monument
When I saw this title I thought of this quote. But then I realized it really wasn't that topic.
But the quote was funny anyway so here it is.
"A doctrine fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end. "
Edward in Vancouver
Thanks for the replies. Actually, I was watching an old Steven King movie, "Christine" and got the turd quote from there.
The carter video was very informational, thanks for the link.
The biggest issue I have with the saw is the "Shudder" when I switch power off. As I said in my above post, without the belt, the motor runs very smooth, and coasts about 30 seconds when power is off--there is no vibration. During operation with blade installed, there is slight vibration, but I can live with that, it's just hte shudder and shale after turning it off that bugs me.
I have borrowed a dial indicator. My bottom wheel--or tire is out of round. The pulley on the bottom wheel is out of round. I don't know how much is "allowable". But I do have a link belt installed, which supposedly absorbs vibration.
Suggestions?
Pete in Holland, MI
Hi Ed -
Often, pretty weak die cast pulleys are put on machines. Any out-of-round, bend, flex, will create vibration.
I replace pulleys when suspect with cast iron or turned steel pulleys and solve many problems.
As pulleys are not true, the belt will get tighter & looser for every revolution of the band wheel pulley. Flexi-belts are only bandaids.
With the motor belt disconnected, slowly (20 rpm) turn the band wheels with the blade installed. If one pulley wheel is out of round, or the tire squashed, you should be able to feel the load on your finger get tighter and looser.
Bad tires create this alternating tight/loose effect on a blade that has no elasticity to it.
Keep searching!
Pete
Edward in Vancouver
Thanks for the advice.
I have trued up the tires considerably with sandpaper. I've also balanced the wheels with both weights and drilling shallow holes. The 6" pulley is out of round, haven't checked the motor pulley yet. Next step will be to replace those. That will be the last money I want to throw at the b.s. other than the occasional blade.
I will however make a stand for it to replace the sheet metal one. This will be constructed with a laminated 2x4 top, and 3/4" ply sides. I plan on storing my 12" planer in the cavity of this, and I hope the weight will be used to my advantage.
