Blade Changing on Delta 22-540 Planer
Ralph Lipeles
I have to change the blades on my delta 22-540 surface planer. I removed the old ones and saw that they are sharpened on both sides. The side that had been down looks like it is sharp and has never been used. so all I have to do is flip them. My planer has springs underneath the blade to push the blade up against the setting fixture. However, I do not have a fixture. Can I install the blades without a fixture?
Re: Blade Changing on Delta 22-540 Planer
Chuck Hans
I have the same planer and I have never tried changing the blades without the height gauge that came with the planer. the gauge pushes the blade down slightly as it rests on the cutter head. I would not try just flipping them without the gauge.
Bruce, a MN Galoot
I have that same one, too, and I don't know how you would set the blade height without the jig. Cheesy as it is, it works really well. I'll lend you mine if you return it.
james runchey
I bought a gadget called Planer Pal, (I think that was the name), and it works very well. It consists of two cubes about an inch or so with magnets embedded. makes changing blades a breeze.
Lars Parrington
have you seen a picture of the stock jig? no reason you couldn't make one out of wood in about 30 seconds.
Plus it's still available
Bruce, a MN Galoot
from several different places on the intertubes for about $8 plus shipping.
