Not OT - Source for 1 1/2" hose
I would like to get a length of 1 1/2" hose for my 14" Delta band saw.
The old hose is cracked and worn. I've got an adapter to 2 1/2" that fits my 1 1/2" hose. The adapters that I've found just don't seem to work well on the Delta fitting (just beneath the table) - but the hose does.
Re: Not OT - Source for 1 1/2" hose
Try a vacuum cleaner store, especially one that sells central vacs as they sell the stuff by the foot.
Be careful cutting metal using plastic hose.
Huh? \
If you use vacuum cleaner hose
Gary Smyth
when cutting metal on a band saw the chips will be hot enough to burn the thin plastic hose.
Ahhhhh,
gotcha. Good advice.
"Cut . . metal . . with plastic . ." did not compute :D
Why would I cut metal on a wood cutting..
band saw??
John Veerkamp
Most farm and home supply places sell various weights and sizes of hose. 1 &1/2 is a common size for irrigation pumps, pool filters and sump pumps. Prices vary based on the quality and strength of the hose.
I hadn't thought about a pool vacuum hose. I see Amazon has lengths of 1.5" hose (for various prices) - I'll probably go with one of them.
Because you can????
Same reason you cut wood, because you need to cut it. Aluminum and other soft metals are easy. So is plastic. And then there is the story about the guy who cut up frozen fish and did not clean up as well as he should. (Anyone smell a rotten fish here.) What you can cut on a bandsaw is only limited by the imagination. Just because you can doesn't mean its a good idea. I needed to cut hundreds of pieces of copper tubing and did it nicely on my bandsaw. Then realized the dust collection did not work well on the heavier metal filings. Wasn't worth it. took longer to clean the tires and other parts than it was worth.
Some one suggested one of those carbide tipped metal cutting circular saw blades. I have seen one in use one a cut off saw cutting angle iron. I wanted to stand about two hundred feet away and wear two layers of eye protection. Blazing iron filings anyone?
David Barnett
Beat me by two minutes
