Re: I keep getting these calls???? OT
rogerincolorado
I live in Colorado. The telephone company (CenturyLink) has a feature (no extra charge) called "Security Screen".
The way it works, after you set it up, is this: Anyone who calls your number, if their phone company does not send through their caller ID, or if their caller ID doesn't match the phone they are using, or if the area code is not valid or if they have "blocked" their caller ID or if their number is "Private" or unlisted, etc. then before the call will ring into your telephone, they hear a message that tells them they must key in their telephone number. Robots aren't programmed to do that, so your phone doesn't ring. I haven't had a message from "Rachael from Card Services" since the service was implemented.
I don't know if it will eliminate robo callers from political campaigns or not. Will just have to wait and see. What we do know from all of this is that the National Do Not Call registry is not just a joke. It is another example of wasted taxpayer dollars AND a joke. My research failed to turn up any evidence at all of any enforcement at all, but the bureaucracy supporting it is, you guessed it, massive.
That is really inconvenient for valid callers whose own telephone companies aren't sending through their caller ID, but it has completely eliminated robo callers.
I suspect that the calls you describe are actually searching for valid telephone numbers. When you pressed 1, it told them that your number was good, not just a dead end.
I don't even answer my cell phone anymore if I don't recognize the number. I wait until they leave a message and then check to see if it's someone I want to talk to.
