Re: OT Car Guy? Changing AC clutch?
Mark Nowicki
I recall you asked this question before. Did you ever find out if your truck has a cabin air filter?
"The clutch is weak" is a meaningless statement. How did the mech. measure the "strength" and what is it supposed to be?
Before throwing any parts at the problem, approach it in a systematic way. Either buy a service manual or subscribe on line to Mitchell DIY. I have the Mitchell, it cost me $30 for a year's subscription, and I strongly recommend it.
Is your A/C system fully charged? Do you have the tools to check?
www.ericthecarguy.com has a series of videos on checking and charging the A/C system
How is the tension of the accessory drive belt, and when was the last time it was measured properly with a tension gauge? How old is it?
Is there a squeaking noise coming from the A/C clutch?
Are the electrical connections on the A/C clutch clean and tight, or loose and corroded?
Is the clutch clean or does it appear oily? Can you remove the drive belt and give the clutch a shot of brake and electrical contact cleaner?
www.rockauto.com sells the A/C clutch separately, so the car knowledge of the AutoZone guy is also suspect.
Do you have the tools to do the job including pullers and ideally, a torque wrench?
To repeat, check out www.ericthecarguy.com. He also has an active forum.
Another good auto repair site is www.realfixesrealfact.com.
Mark
