A55 Smoothing Plane
Lambs bonnet
Lambs bonnet
Dale Lenz
Lambs bonnet
Dale Lenz
Once in a blue moon my buffing bonnet comes loose from the rubber disc that it is glued too. In years past, I've gone out and purchase a new one, 15+ dollars. Has anyone had luck gluing it back on? If so what type of glue did you use?
TIA
Re: Lambs bonnet
Just don't buff on the 2nd full moon of the month.
Re: Lambs bonnet
Lambs bonnet...I'll ask them
Bill Tindall, E.TN.
Wool stays stuck in my sheep just fine. In fact I have to shear it off....and soon they tell me. I'll ask what they use.
E6000 sticks anything. The heavy body 3M spray is also extra sticky. The stuff that is used to attach head liners in cars (some urethane stuff from body shop supply) might work. Barge cement works for leather.
Re: Lambs bonnet
What About
that stick adhesive they (used?) to use to adhere abrasives to disc sanders? I remember it was heat-activated but would hold the heavy paper until it was literally scraped off to put a new disc on.
Re: Lambs bonnet
Dale Lenz
Thanks, Bill and Mark...
Dale Lenz
I'll let you know what works. The bonnet came loose Monday night, used some contact cement and clamp in my vise. Went out last night to buff another piece and discovered that I sanded through the finish, #$%&. Might be buffing another piece tonight as the other piece cures more before more sanding.... Have some 3M spray of some type out there.
