Last year I had to replace blade shaft bearings on my PM 64A contractor table saw. This also required removing and reinstalling the blade height and blade tilt mechanisms. Ever since it was put back together the blade is parallel to the miter slots when at 90 deg, but out of parallel when tilted to 45 degrees. Called PM support and the person kept saying I had to adjust the blade to "level" when at 45 deg. when I questioned what he meant by level he said I had to get a combination square and use the 45 deg end, then insert washers as needed to level the blade. When I asked again what he meant be level he said I needed to call a service center.
The blade saw parallel to the miter slots at both 90 deg and 45 deg before I had to disassemble.
Can anyone offer some guidance as to how I can try to correct this issue? Thanks.
Here is the info you need. It was in a Delta publication but works for a standard Contractor Saws.
There is a significant area of alignment that is not detailed in most magazine tune-up articles. It is ensuring that the trunnion bars are exactly in the same plane. Proper adjustment affects bevel cuts and is indicated when there burning when making bevel cuts. Here are the corrective steps that were at one time posted on the Delta website.
First go throught the alignment process following the steps in the attachment below.
To check whether the trunnions need to be adjusted, tilt your blade fully to the 45 degree position until you get to the 45 degree stop. Then crank the blade back to the 90 degree upright position. Now again check the parallelism of the blade to the miter slot. If the blade is still parallel to the miter slot, declare victory. If not, follow the process below from Delta to adjust them. The process is the same for all Contractor Saws or Hybrids that have the trunnion assembly hanging from the table.
1. Remove the saw blade being sure it was at it fullest height.
2. Place a flat plate (or similar flat object) on top of the two tie-bars. (The size of the plate should be at least 6" by 8", and the flatter the better. A pane of glass works well.) Depress one corner of the plate and if it rocks, the tie-bars are not parallel. This must be corrected as it will affect the alignment of the blade.
3. Loosen the tie-bar locknuts located at the rear of the saw.
4. Grasp the motor bracket and move it left and/or right. Check the rocking of the flat plate and when it can no longer rock, the tie-bars are parallel...re-tighten the locknuts.
5. Remove the flat plate and re-install the sawblade.
6. Again perform the parallelism alignment process.
7. Before tightening the rear trunnion bolts, push forward on the rear trunnion bracket to allow the undercarriage to snugly fit between the two trunnions.
When tuning a TS there are two angles that need to be adjusted. One as you already know is having the blade parallel to the miter slots at 90 deg and the other is having the trunnion parallel or level if you will to the table top front to back. It could be that when you reassembled the saw that you incorrectly placed a washer or a shim. When you tilt the blade to 45 deg and measure from table slot to blade on the same plane it must the same at the front of the blade as the back of the blade. So let’s say that your measurement at the front is wider then at the back. This means that the trunnion is lower at the front then at the back and that you need loosen the back two trunnion bolts to put shims between the trunnion and table top to make the trunnion level. Just do the opposite if the back is lower. This is of course after you have made sure that the blade is parallel to the miter slot at 90 deg before you started. When you Think you have made all the correct adjustments recheck all of your alignments at both 90 and 45 deg. This can take awhile and be a bit fussy but take your time and you’ll get it.
Thank you Howard and Sophie. I printed two copies of both your instructions and will "get dirty" one day next week while the glue in dovetail joints is drying.
