A55 Smoothing Plane
LI Batteries
LI Batteries
LI Batteries
Bob in NE Ohio
I had a strange happening yesterday! Two of my 4 Ryobi LI batteries showed up as defective on the chargers on the same day. Both are about 2 or 3 years old, purchased at different times, but they were working fine the week before. One is the full size and the other is half size. Is it likely that they both would die at the same time or could it be one of the chargers causing the problem?
Is there any way to recover the batteries or are they toast?
Thanks for the help
Bob
Re: LI Batteries
Re: LI Batteries
John McGaw
It seems unlikely to me that both batteries would fail simultaneously on their own but, like you say a charger might have killed them (worst case) or might by lying about their state (somewhat better case since you have two chargers). What is the commonality between the failures? Both charged on a single device, maybe? If so then trying the other charger would be a first step. If your charger has a 'maintenance' mode it might be good to try that out. I don't know how yours might be selected. Old DeWalt chargers actually had a button for the purpose but their newer ones supposedly do the job automatically.
Re: LI Batteries
Re: LI Batteries
del schisler
some of the old chargers won't charge battery's if the voltage is below 3 volt, if you have a volt meter check, if below 3 volt take a battery and use jumper's and hook up or flash for just a sec. like hook up 1 wire to both battery's and than the other hook up 1 end and than flash the end for just a sec , now check the voltage if above 3 volt it should charge. good luck be sure and use the outside to outside spade lug and than the inside to inside spade lug
Re: LI Batteries
Re: LI Batteries
Lars Parrington
could this be a battery temperature issue? if i drain my ryobi LI batteries fast, they get warm to the touch. i think the charger won't start charging them until they've cooled down a bit, and indicates this by flashing its LED in a certain pattern, which may be the same as the defective battery pattern.
