Delta 12" Planer
Delta 12" Planer
Delta 12" Planer
Ralph Lipeles
The depth adjust on my Delta 12" planer loosens when planing hardwoods. I have to either hold it in place or tape it in place. Is there an adjustment that will tighten this setting so that it will not vibrate loose during a cut?
Re: Delta 12" Planer
Lars Parrington
i also have a 12" delta planer, lunchbox type. the depth adjustment handle on mine will rotate a bit while planing, up to ~1/4 turn from where i set it. i haven't really investigated it, but i've been assuming it's just backlash in the mechanism that allows it to rotate, and that the depth of cut is not actually changing. i'd be interested to hear what you find out.
mine looks like this:
Bruce, a MN Galoot
Turn it upside down, and you will see the lock nuts that will allow you to change how it tightens the adjustment mechanism.
Robin Corell in Atascadero,CA
The two threaded rods, one on each side become worn over time. I replace a set on my old planner and the were sure for another when I replaced the planner. By the time I got rid of out the while thing was worn out.
Robin
JMOHNIKE
I have had the same problem with my old 10" Rioby. I place a large magnet on case on the bottom side of the handle which prevents it from moveing. In my case it was not back lash the depth of cut changed.
Ralph Lipeles
Thanks Robin. I turned the planer upside down and the ends of both threaded rods were visible. I then tightened the Nylock nuts at the end of each rod. Not a lot. Maybe a few degrees, not a few turns. I then tested the depth knob and it felt tighter then before. I did a small planing and it seemed to stay put. Time will tell if this fix will stay fixed. I hope so.
Ralph Lipeles
