More LED Lighting
More LED Lighting
More LED Lighting
John McGaw
I was just finishing up installing the curio lighting in the bookcase downstairs and, since there seems to be a bit of interest in LED lighting, I thought I'd post a picture of the result. The lighting I installed is probably a bit of overkill since it can easily hit 50FC at the rear corner of each shelf. Luckily the lights are easily dimmed (by remote control, no less) and will never be run at full brightness. Some day I may even get around to finishing the trim in the "library" and get the floor laid but one step at a time...
Re: More LED Lighting
Henry (Raleigh, NC)
and so which LED product did you use - and where did you get it?
Henry
John McGaw
Three separate bits from Amazon:
1) LEDwholesalers Waterproof LED Driver Transformer 60 Watt 12V with 3-prong Plug, 3204
2) Lighting EVER RF Dimmer of LED Strips, LED Ribbon, LED Lights, Wireless Control
3) HitLights Warm White Double Density 600 LEDs Flexible Light Strip, 3528 Type SMD, 5 Meter or 16.4 Ft, 12 Volt, 48 Watt
Other that this there was 22ga hookup wire, solder, some heatshrink, hot glue, and strips of wood beveled at 45-degrees to aim the light down toward the rear/bottom of the boxes, and some MDF scraps to make custom moulding to hide the wires. The bits from Amazon came to $61 but the other gubbins were already around.
Re: Question for John McGraw
Rick Snyder
Hello John,
I have been asked to build a similar type of book case as you have built. What type of material did use for the construction of the sides and shelves, (solid, ply, laminated solid wood)? Do to the distance to the customers site, it's not possible to build on site. My thoughts are in the module type construction (it's a 10 ft wide space). The customer is going to paint the shelves. They also do not want a back on the the book case.(s) (construction problem??)
Thanks Rick
John McGaw
Due to financial limitations I was forced to build my shelves from MDF but it was the highest quality that could be had from a supplier to commercial cabinet shops. A really big advantage, given my tiny shop and lack of help, was that it was already accurately pre-cut to 12" width.
The top, bottom, and fixed shelf are attached to the sides using 7mmX50mm Confirmat screws (18 per module). The backs are held on using glue and 1" 16ga brads. As you can see there are five modules spanning the room width of about 16 feet. The height was limited by a duct soffit while the modules rest on a 2X4 frame which was shimmed level. There are 3/4" spacers between the modules to provide the desired spacing. The face frame is constructed of 3/4" maple which I had around and all of it is 2-1/4" (3/4" X 3) wide. There are biscuits holding the face frames to the movable shelves but at this point I can't remember if I used them elsewhere. I put 32mm "Euro" holes in the sides to allow for movable shelves.
I would really hesitate to make such shelves without backs, they being the only thing which provide any substantial rigidity and prevent racking. Confirmat screw construction is strong and all that but they can only go so far and the face frames are probably too insubstantial, being pieced together loose.
If money had been flowing more freely I would have made the carcases from 3/4" MDO plywood since it paints so beautifully with no preparation but it was too rich for me.
