Tool use in cold shop?
Tom
Since my propane ran out and I will not be re-filling it for so time I have a question. When the shop get down to 32F and below can it harm the power tools to use them at this temp?
Thanks
Tom
Thanks
No, But
Don't lick them
Re: Tool use in cold shop?
del schisler
no tool's would be ok, just to dam cold to do much ,but paint and glue ?? shouldn't get that cold
Couple things
Dale Lenz
If the interior of the shop reached the dew point, moisture on metal surfaces I would not use power tool as you might have moisture inside motors or other electral devices. Also, your finger don't work well in a cold environment and you could get hurt, so proceed with caution.
but the cold will slow the blood loss;)
Define 'cold'
Tom Dunlap
Right now I'm in Asheville but I lived in Minneapolis for most of my life. My shops were always unheated...until I fired up the furnace. Unless I was going to be in the shop for a while I would work at ambient temps. No matter what the outdoor temps were it was always 10 degrees warmer inside.
If condensation were really a safety issue then everyone who reads this would either have gotten shocked/electrocuted or know first-hand someone who would have.
This concern, to me, seems to fall into the myth of static electricity causing car explosions at the ga station. Considering the gazillion times both of these things occur there would be lots of funerals if there was really a concern.
Doesn't electricity flow better at low temps? Wouldn't cold temps make tools run more efficiently? Joke
If I remember my physics that isn't an issue until closer to absolute zero...colder than it gets even in Minnesota!
Tom...chilling in Asheville
Re: One thing
Don't know about you, Dale, but my finger works quite well in the cold; especially when the fool next door is blowing his driveway clear by dumping it all on mine.
Consider related effects
Jesse Cloud
If my wife noticed me working in a frigid shop, then one of my best excuses for avoiding yard work would vanish. Right now she buys the notion that I'm too old to go out in the cold and prune trees, etc. So I try not to use the shop until its 60 degrees or so...
Re: One thing
Dale Lenz
Read your message twice before it dawn on me what you meant,
Only hitch is....
John in NM
he was wearing mittens
Got a good one for you...
John in NM
In this drought, only prune trees you want to kill
Unless they are junipers, ya can't hurt those things....
Yo
Dis is Jersey. I jus tell'em ta read between da lines . .
Sort of . . .
Steve Mackay
I've left a bit of skin behind on them when it was cold enough to stick to them.
Won't hurt the tools...
John in NM
I often work in the shop before the fire warms it up, and before that down in a horrible basement shop. I don't know as either gets much below 32 as water bottles we left never froze.
Only thing that was much of a problem was using the table saw. You don't notice the "wind" so much when the shop is warm, but when its cold I find the TS breeze to be fairly unpleasant
Expect a coat of rust on everything
Dick Coers
when it warms up. You'll have cast iron at 32 degrees. It warms up to 60 and high humidty from a rain, everything will have a layer of condensation on it. Cast iron flases over quickly with rust. The worse thing? All the surfaces inside the machines without paint on them, will do the same thing.
what about lubrication
Bill Tindall, E.TN.
Are the lubricants used in these machines designed to function at the colder temperatures?
No. See Tom Dunlap's reply.
Bruce, a MN Galoot
I have my dad's tablesaw that he bought new in 1964. He was a carpenter, and we used it on unheated job sites year-round in North Dakota, where it gets considerably colder than 32F. That saw performed without a hitch, never being used in heated conditions for at least 4 months of the year. So did we
. I routinely work in the shop in bare hands at 32F.
The motor from that saw still powers my strip sander, and runs in my unheated shop at temps as low as -10F (I don't work out there colder than that).
However, I would have a problem using an unvented propane heater. I did that exactly one time. The heater kicked out so much water vapor that every tool in my shop was covered with a fine coat of rust the next day.
housebuilders
Jerry Gibbs
Don't house builders, framers etc. have this problem when they work in cold weather and the building is not yet heated?
Nope
Re: Should be fine
I have often used power tools in very cold temperatures as a contractor. The only issues I can see are 1) you may have some difficulty (stiff) making adjustment to your saw, joiner and planer depending on what lubricant you have used. You will not have any condensation problem unless you bring in warm air (or heat with a non-vented propane heater) as the ambient humidity is at the "cold" temperature and will not condense on any surface at that temperature (or warmer). However you will get some condensation on any iron or steel in an unheated area (not in use) as when the air warms up during the day, it will "adsorb" moisture and the iron normally will stay colder than the air for quite a while - until it heat up moisture will condense on your machines. Much like it condenses on your glasses on a very hot day when you leave a air conditioned area, or when you come into a warm area after being outside.
