Compound miter outside cut 24deg
Joe Vultaggio
I've got a Dewalt chop saw and need to know how to cut 24 deg outside corners.
How far to tilt the head, and what angle to turn the table.
If there are more than one way, whats the easiest.
Joe
Re: Compound miter outside cut 24deg
Re: Compound miter outside cut 24deg *LINK*
Rick Christopherson
Here is a PDF with a compound miter calculator built into it. This is an excerpt from my Festool Kapex Supplemental Owner's Manual.
You need to know the slope of the moulding. Even though 38/52 is common, it is not universal. The article describes how to measure this.
Oops. Apparently the forum won't link to a pdf, so you'll have to put it in manually. (although I'll try the link one more time.)
http://www.waterfront-woods.com/festool/Compound_Miter.pdf
