A55 Smoothing Plane
OT - reinstalling acoustical ceiling tile
Howard in Toronto
Some of the old-style ceiling tiles in the office have given way.
I just tried repairing the dozen or so that have fallen off. I armed myself with a mallet, a whacking stick so as not to damage the interlocking lip and a manual staple gun.
Aaaarrggghhhh
Talk about an exercise in frustration. My wife couldn't hold up the remaining sagging tiles (their cumulative weight adds up) and my taller-than-me-by-six-inches youngest couldn't manage it either.
BTW - my compressor has a 35-gallon tank and I don't feel like rolling it down the basement stairs even though this'd be a perfect opp to buy a pneumatic staple gun.........
Any suggestions?
Thanks.
Howard
Re: OT - reinstalling acoustical ceiling tile
John Veerkamp
Electric staple gun!
Henry (Raleigh, NC)
at this point I would
1. Find a friend with a much more portable compressor - I have one you can borrow, but I suspect the drive won't be worth it. Could rent a compressor - for about the same cost as a new pneumatic hose)
2. Buy/borrow another (or a longer) air hose so you can use your compressor but not drag it down stairs (cheaper than a new compressor certainly).
Henry
Joseph Mulherin, sr
Howard, when I was just a plebe in the Trades I noticed the guys installing the tiles at Purdue University at the first "H" building for men. They applied a swab of mastic to each corner and then applied each tile to the concrete ceiling. After many other buildings like this were built I went over one day on a repair request and noticed they were all still in place.
Longer Hose and a dead man.....
Buy a cheap longer hose. The Borgs have them for as little as ten or fifteen bucks.
Then use a Dead Man to press the tiles back up if you don't want to remove and re-install them. The Dead Man is a stick with a plate on one end. Take a scrap of plywood maybe a foot square and attach it to one end of a 2 x 2 or even a 2 x 4. Make the length about a 1/4 or 1/2" longer than it needs to be and then use it to press the tiles up. It helps if the stick is flexible and you can bend and spring it into place. You might need two or even three. It helps if the plate is loose enough to hinge a little on the way in. You can also use wedges under the bottom to increase the reach and pressure.
I lived in that building!!!
Neal in San Jose
Purdue came up with such clever names for those buildings: H-1, H-2, etc.
At the end of my freshman year, my roommate and I were going to be charged for damaging a couple of the tiles in our room so we came up with a repair solution. We filled the damaged areas with peanut butter and colored it with white shoe polish. We got all of our damage deposit back! I always wondered how it held up, tho.
Jason Roehl in Lafayette, IN
AFAIK...
They're all named, and have been for at least 28 years (when my oldest sister started there as a freshman).
The dorm I lived in my freshman year became a parking lot the following year (Fowler Courts). Now they've built some pretty fancy new dorms there. The amount of construction I've seen on that campus in the last 20 years has been mind-boggling.
Jason
