(Message Deleted by Poster)
David Barnett
Re: (Message Deleted by Poster)
Great resource. Thanks.
Since I haven't been keeping up with the latest LED developments, can anyone tell me if they've figured out how to mimic the color temperature of a tungsten filament? And are low-voltage dimmers affordable?
What is your experience with
Gary Smyth
driver hum? At 5000K and 6500K, "white" lamps, a typical month done installation develops hum that in my examples, gets worse over time. The only solution thus far has been to isolate the driver away from everything electrical around it which defeats the value of space savings, as now there are wires spread out in two locations, or replacing the driver which has turned out to be a temporary solution. This started with IKEA strips but has continued with Utilitech and finally Luxstrip. Any problems with what you are using? The LEDs can get pricey and I've pretty much decided to wait experimenting until they can get the problem resolved.
David Barnett
I never considered too much. And another
Gary Smyth
Would a downstream voltage regulator set for a peak of 12v stop the problem? I'm no engineer and can only sometimes find the correct button to push to even turn on a light, but if what you term boost is the problem I'm thinking that that might work. If so I'm wondering how much additional one needs to spend to insert a top quality regulator. I'm not skilled enough (or have the personal interest) to do all that you do to achieve noise level reduction goals. But I hear that hum to the point it distracts me. I EXPECT that a premium product would have come up with a solution for a flaw that they apparently know exists. In my thoughts this is analogous to Microsoft releasing products before they are thoroughly vetted and letting the customers complain, and then patch a fix -- LEDs 2.0. Perhaps you ought to sell your solutions. There is a need.
The other, have you heard anything about high intensity LEDs in the daylight range fading/harming paintings and prints?
David Barnett
Thanks for the detailed reply.
Gary Smyth
Having read the definition of boost, I will have to withdraw. I'll let time and others work out the problems. Way beyond me. I'll wait it out.
