Shop-made lathe sanding atch
AZ in Colorado Springs
Last November the local woodcraft store had a sale on Rikon mini lathes. About the same time Popular Woodworking Magazine published an article showing how to make a disc sander attachment for lathe. Excellent timing -- I bought the lathe while it was on sale.
I just had to adjust the dimensions for the smaller lathe. One thing to consider if you decide to make such an attachment for a mini lathe: Small lathes have the motor tucked up right under the lathe bed, so there is little clearance for an under-the-bed mounting system close to the head end of the bed. (Large lathes have a lot more open space under the bed).
In the photo the attachment is not close to the sanding disc. I had to modify the piece underneath that clamps to the bed to clear the obstructions.
It's a great addition to my shop -- and now, two machines for the price of one! It works great.
Cheers
Re: Shop-made lathe sanding atch
Enjoy . .  But
Be prepared for the sanding grit to get into your headstock bearings and fry them to medium rare. Many HS bearings are not "doubler sealed" and if the grit from your abrasives gets in there, they will self-destruct in fairly short order. Have a dust collector hooked up and running. :D
